DIY Cheap Mods
Let Me Know What You Think? All You Rideing Bros
It Was Fairly Easy To Retrofit,,, Ace Hardwear And My Dremel Tool And Wala .
It Did Come Out Nice,, I Was Very Happy.
THEY Are Stainless Screws I Polished Them Up With My Dremmel Tool
Yes It Was A perfect Fit ,, Just A Littel Dremel Work On It, No Biggy
I'LL Take Some And Post In A Few Days
I Got The Lights On E-bay Here >>> http://stores.ebay.com/Classy-Chevy-USA-Parts
Cost $44.00 + Shipping To South Florida Of $9.70 For The Pair I Did Not Use The Bulb And Base That Came With The Lights
Ok Here Is The Update On What I Cut And Drilled , I Hope You Can Read It, If Not Just Copy And Paste To Make Larger To Read,, This Is The Best That I Can Do With My Tech Knowledge Ha Ha, This Where I Got The Lights On E-bay Classy Chevy USA Parts $44.00 + Shipping
This Is Where I Got The 90 Degree Bulb The Bulb Burns Red Or You Can Get It In Amber If You Get The Clear Lenz Caddy Lights
http://www.waltersworkshop.com/bulbs-lighting.html
1156 90 Degree Red L.E.D. Bulb
For use in rear directional of FL mount. A must for clear lenses.
Price: $18.95 Each
Have Fun And Enjoy
Harley03joe
P. S. Don't Forget The S/Steel Star Washer Under The Screw
Yer Right I Did Save A Lot Of Money,, It Was More For The Challenge Then The Money Really,, I Looked At The J&P Light Real Close,, It Looks Like To Me That There Is A Spacer Between The Light And The H-D Light.
Truth Is The Caddy Lights Might To Big And Long On Your Bike,, You Have A Bar Hopper Ha Ha.
I Put In The H-D Modules On Mine I Now Have 3 Brake Lights And 3 Running Light And The Turns, I'm Going To Get The Blue Dot Lenses Next
NEW PICTURES OF THE CUTS I MADE , To Fit My 03 Heritage.
I Got The Lenses From
Click here: eBay Store - Classy Chevy USA Parts: Rat Hot Rod ACCESSORIES, Tail lights and Lenses, 1955-1957 Chevy Car parts
Heres The Cut Pics
Enjoy
Harley03joe
The Dremel Is One Great Tool.
H-D Sells A Short Light Bar Thats What I Have On Mine,, The Short Bar Looks Better When I Ride Bag less.
Get This Kit And You Can Have All 3 Lights Working Stop, Running, Turn All At The Same Time,, Very Cool
Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit
Product ID: 69461-06A
Price: $57.99
ENJOY AND HAVE FUN
Harley03joe
Even the local Tractor Supply doesn't have much, at least not in stainless.
I don't know of any Ace's around here, but I'll try looking them up and see where one might be. I do a lot of traveling around the state for work, so there HAS to be one around somewhere.
Thanks for the tip.
Citoriplus:
Next time you're over in Albany, stop into Phillips' Ace Hardware- they're on Central Avenue in Albany, a few miles east of I-87 Exit 2E. I believe they own a few Ace Hardwares around the Capital District, but the Central Ave store is their original location.
Now, I've not been in there in almost a year, but I know it's a large Ace Hardware...if I was home, I'd swing by and give you an idea if you were to hit paydirt, but alas, I'm in the Sandbox until June. But in June, I'll check if you don't make it east!
Also, I believe Ace has (or had, until recently) a distribution center up around Glens Falls, so there are a handful around Capitaland.
vhmike73,
Don't worry about it, you just remember to keep your head down, your butt covered and come home safe.
I found a closer source, its not perfect, but it is closer.
Thank you for your service.
I Get A Lot Of My S.Steel Here
http://www.chromebolt.com/chrome-ste...99e80a39f157cd
I'm just one of the foolish ones who vuolunteer their time to try to keep things running smoothly.
PS For those of you who don't know, this site is owned by an outfit called Internet Brands (I think that's the right name).
They own/operate a number of 'Brand' specific web sites like this one.
Yes I know my bike is dirty, been a long year and they finally paved my road so hopefully it'll be easier to keep clean now.
Very clever idea, I like it and am going to have to see if I can try it.
I like mine where they are (down at the bottom tree, but I'm not satisfied with the clamps.
You would need to get a slightly longer bolt to replace the one in there now.
I don't think you can use the original because its part of the fork tube clamping 'system'.
Haven't pulled mine apart, yet. But I believe it bottoms out on the tube itself and putting a plate (for the turn signals) under it would be like sticking a large washer in there and it will not be able to touch the tube anymore.
While I think using 35mm Bushmaster cannon shells for pegs is a great idea, I think they may be a bit too big and long for the job.
A 20mm M-61 Vulcan cannon shell or .50 cal. dummy rounds would fit better.
Both are better sized in both diameter and length, with a projectile installed, for pegs than the 35mm would be.
It shouldn't be too hard to drill and tap or drill and epoxy a threaded rod (made from a grade 5 or 8 bolt) into the base of a dummy round to fit the peg mounts fairly easily.
