DIY Cheap Mods
Old Jan 21, 2009 | 01:55 AM
  #171
Reverend's Avatar
Reverend
Originally Posted by mopardave
I'm not gonna argue with ya,...LOL
But you're always up for it.
Who cares if it's in the wrong section, it's a hobby ferchrissakes!
Old Jan 22, 2009 | 11:51 PM
  #172
tampachris's Avatar
tampachris
Default Lay down license plate
Does'nt get much cheaper than this, I removed the L bracket from behind the license plate and bent the sonabit## down! Cost $0. Not sure if it leagle but other than the light not quite hitting the plate cant really tell. I do plan to do it right at some point.
Old Jan 22, 2009 | 11:54 PM
  #173
tampachris's Avatar
tampachris
not sure if i know how to spell legal
Old Jan 23, 2009 | 03:47 AM
  #174
mopardave's Avatar
mopardave
Me for one and Harley03joe and Citoriplus, who happens to be a mod and also the original poster....so STFU!!!
You can leave that crap in the "Political and Open Discussion" section. If you would read a rule or two some time, you would know that.
It takes long enough for guys to thumb through all of these "cheap mods" as it is.
Old Jan 26, 2009 | 03:56 PM
  #175
JRK5892's Avatar
JRK5892
I believe that you have it reversed. Wired in parrellel like he has reduces the power (current loading) going through the LED. Wired in series the power has no other path to take but through the LED.
What you are doing is confusing voltage with current. Voltage is like velocity, where current is like volume. The LED can handle the velocity, but it has a hard time dealing with the current or volume
thanks man! i did not know that! good little tip there!
grips and bolt ons are NOT "mods" they are check book style upgrades. cookie cutter tips that will make your ride look like every other one in the harley parking lot... i would go NUTS if my ride looked anything like another bike out there
Old Jan 28, 2009 | 01:11 AM
  #176
cncfxstb's Avatar
cncfxstb
Originally Posted by Citoriplus
Here's a cheap way to help get good solder connections when you need to lengthen, shorten, or add lines in the bikes electrical system.
The biggest problem with soldering wires on a bike is you need to be an octopus. You need a couple of extra hands to hold the wires whileyou use solder with one hand and the iron in the other. So I came up with a simple and cheap way to make a couple of different wire holders.
nice idea butt..... that is a pretty big solder joint, not that impressed.
Old Jan 28, 2009 | 07:13 AM
  #177
gunner065's Avatar
gunner065
Oh no! The solder police are here.
Old Jan 28, 2009 | 08:13 AM
  #178
Trailfndr's Avatar
Trailfndr
Big??? Lets see, a Cloths pin is less than 1/2 inch wide...so there is about 1 1/2 inches between the clamps, meaning the joint itself is 1/2 inch or LESS. thats not too large to insure a good joint.
Granted it looks larger, but he took CLOSE-UP Photos for clarity
Old Jan 28, 2009 | 10:54 AM
  #179
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
I didn't solder it that way to impress anyone, I did it to illustrate a point.
Come on give it a rest, most of the people on here have very little or no experience playing with soldering irons.
I was only trying to show them what a good solid connection should look like.
On bike's like ours with paint can shakers for engines there really isn't much need for adherence to strict NASA standards.
Its just gotta work, and be reliable after that its all gravy.
Old Jan 28, 2009 | 01:20 PM
  #180
mopardave's Avatar
mopardave
If I use your method of soldering, I'll probably need a side car to carry the splices around with me!
Geez! There's nothing wrong with your solder joints, they look fine. CNCFXSTB is a troll.
