DIY Cheap Mods
Old Aug 4, 2012 | 09:22 AM
  #681
EZ Rider's Avatar
EZ Rider
1st Gear
Originally Posted by Poolguy
Hi everyone. This is my first post here and wanted to tell ya about a mod I have done on my Heritage. I have added the Harley passanger foot boards for my girl and she loves them but complained that they were to low and on long rides the backs of her legs hurt. Kuryakyn makes foot boards with an adjustable peg to raise your feet and change positions but not for the softail so I decided to make something similar. If you notice on the Harley passanger footboard, after you put the footboard on the hex shaped peg and put the bolt through to secure it, there is a 3/8" space of unused hex peg on the inside. There was my mount point. I took a piece of 3/8"X2" flat bar. Cut the hex shape out to fit the peg and drilled and tapped for a 1/4" set screw on the bottom to tighten it up on the peg. Had to do a couple of bends to bring it in about an inch so the foot peg wasn't sticking out to far. I used the old passanger foot pegs I took off. Ended up raising her feet about 4". Takes a few on and offs to get what you want but they turned out awesome and my girl uses them more than the boards. I will send some pics.
Would really like to see pics of this finished out, putting passefnger floorboards on very soon.
Old Aug 7, 2012 | 11:25 PM
  #682
camo36's Avatar
camo36
Originally Posted by Midgard
Couldn't stand the chrome trips anymore and until I can afford to replace them I painted em up with this - no prep and bonds to hard to bond surfaces ie; plastic, metal etc... http://www.krylon.com/products/fusion_for_plastic/
45 min of taping and a couple pieces of vapour barrier I had lying around = black trips - (and I hit my marker mounts at the same time)
i removed my lower chrome piece under the headlight mount and sprayed it with high temp bbq grill paint for durability, then sprayed nite shades over that. looks pretty good. lookin to do the rest of the trip like you did but without the prep that i needed to do cuz i dont feel like taking it all apart.
yours looks real good, how long has it been and hows this stuff holding up so far?
Old Sep 18, 2012 | 09:39 AM
  #683
WellsFargo's Avatar
WellsFargo
Originally Posted by aviator
saying the ribs on the oil tank help with the cooling is like saying FatBoy wheels are worse in the wind...... it's a myth.
Laws of physics says driving in high winds with solid wheels versus with spoked wheels will be a factor. It's no different than when I ride my deluxe with the windshield versus without. With it, on windy days, I can feel the bike pushed an pulled by the wind on some instances. Without the shield, it is not noticeable. I like this thread by the way.
Old Sep 18, 2012 | 10:13 AM
  #684
Quadancer's Avatar
Quadancer
I replaced my spokes with Fatboy wheels after pulling hard in the twisties with a trailer behind me was breaking spokes and had me constantly relacing the back wheel.
The ONLY time I feel those solid wheels down there is when I'm being buffeted when temporarily behind a tractor trailer, where you get slammed around anyway. Crosswinds have thus far not affected me to any noticable degree in the last year or so.
Old Sep 19, 2012 | 09:01 AM
  #685
WellsFargo's Avatar
WellsFargo
You don't mention how you attached the round stock to the flat stock. Did you weld that? I've been wanting to make something for a while now, also tired of melting my heels onto my shiney pipes.
Originally Posted by colonelangus1
ok ive melted my boot on the exhaust for the last time..
my boot heel has mellted on the exhaust more than once ..carl miles heel guard for harley footboards are $68.00 on ebay for $3.00 worth of material..their instructions show spacers to clear side lip of floor board i notched mine to allow for better fit and it will be much stringer this way will also slot 2 of the holes for adjustment..
so i decided to make my own..simple but effective.the pic above shows the turn out style they also make a turn down and a smaller straight guard..i decided on the smaller straight style.
materials needed:
6" - 3/4"x1/8" flat bar
6" - 5/16" round bar
2 - bolts of choice [ i went with 1/4" stainless with nylocs ]
so heres a couple pics first i cut the flatbar to length then bent it at 90*.then cut the round bar to length and chamfered the ends
ok now time to cut the edge of the footboard to fit the 3/4" flatbar so i cut a 3/4"W x 3/8"D knotch in the side
time to drill some holes and countersink them for smoother finish and more clearance
installed on footboard
Old Sep 19, 2012 | 09:03 AM
  #686
WellsFargo's Avatar
WellsFargo
Does anyone know how the heel protector Harley sells handles that possibility?
Originally Posted by LOUJCONST
What happens when the bike tips and the floorboard fold up? Bent pipe?
Old Sep 20, 2012 | 10:01 AM
  #687
bucker18's Avatar
bucker18
Originally Posted by cjwanner2000
here is my contribution for the thread. this is a free mod if you're already buying cables or in some cases the stock cables may reach. i was switching all my cables to the diamond braid ones so i ordered all of them two inches over stock length then i routed them through the hole in the trees. i was running the stock length clutch cable like this before ordering the diamond braid. thanks for a great thread!
man thats a great idea i never would of thought to do that .. i just bought extended cables for my beach bars and will be re running them like this
Old Oct 13, 2012 | 09:26 AM
  #688
Goldtop Dude's Avatar
Goldtop Dude
Like the Floorboard guards ! Will have to give it a try ------
tc,
GTD
Old Oct 14, 2012 | 06:22 AM
  #689
Andyintheshed's Avatar
Andyintheshed
Default Baffled?
More of a question, this....
Has anyone had a go at at a bit of DIY baffle surgery? I only ask because
a) My new Slim is far too quiet - I've already had the 'we're waiting for you to start your bike' gag at the beginning of runs and
b) it would keep the 'standard' look and
c) those rivets look far too tempting to leave alone.
d) would the price of four rivets and a bit of sawing/filing mean this counts as a cheap mod?
Andy
'95 XLH883
'13 Slim
Hampshire
England
Old Oct 14, 2012 | 07:26 AM
  #690
goats's Avatar
goats
are those 3" mufflers? if they are i have the same on my blackline and it was easy to drill out the rivets but you will have to pull the mufflers off to do this.
the first time i did this i riveted the baffles back in but the last time i drilled them out i used #10 stainless panheads with lock washers so i wouldnt have to remove the mufflers to pull the baffles.
you may have more skills than i do but after pulling the baffles out and cutting the rear end off i still could not get the damn things apart.
the idea was to add more holes and possibly bigger ones in the same sort of manner they were constructed, since i could not do that i simply welded the end back on, inserted the baffles back into the mufflers and drilled a half inch hole in the plate you see when looking inside the baffles..... use a step drill so you have options....i have since wondered what a 3/4 hole would have sounded like.
in the end i just pulled the damn baffles completely out but be warned it is stupid loud, deep but loud.
you may want to try the W258 thunder torque inserts from DK customs or something like that to tone it down and recover some back pressure..... mine should be here monday and when i install them and ride i will tell you the difference in feel and sound from each different change i made
Andy
'95 XLH883
'13 Slim
Hampshire
England
