DIY Cheap Mods
Old Jun 27, 2011 | 12:57 PM
  #531
JoeBobber84's Avatar
JoeBobber84
wow the're is a lot of good stuff in here!
Old Jun 28, 2011 | 11:57 AM
  #532
xraybox's Avatar
xraybox
Originally Posted by Citoriplus
Nice job xraybox, but can you put up a couple of close up pics and maybe some of how you did it?
Be worth a lot more to guys who may not be able to figure out exactly how you did it from your description.
I can try and describe in more detail, the holes are 3 1/4" center to center, (about 4" overall)
After sketching the design (roughly the same as what I'd seen for sale)
I drilled the holes
used a bench grinder to rough grind the shape
then put two bolts to keep them aligned
then finished grinding to final shape
made the inboard end slightly larger than the windshield mount grommet
made the outboard end slightly larger than directional mount
Made sure they were long enough to drop below windshield
used a 4" grinder with a "flap" disc to "ease" the edges
Rattle canned them, first primer, then matte black
Purchased 4 (2 long &2 short) stainless steel button head bolts (I think they were 1/4" longer than original)
I used a small washer between the directional and the bracket, to make sure it didn't get gouged when I rotated it.
Loc-tite on the bolts, made sure they were level Tightened them
Took off the original brackets, and stuck a 1/4"(err 3/8") spacer (rattle canned) on top of the mirror stem, allows the acorn nuts (I can't remember, you might have to pickup a couple Stainless) to tightens up without having to cut the stem.
right now the wires are wire tied out of the way, once I get beach bars on, I'll tuck the excess under the tank.
The brackets I saw on-line, had what looked like a tab on the inboard end, my guess was to keep it from moving, but because of where I was mounting mine, a tab wouldn't help
7000+ miles, and they haven't moved
looks like it wasn't needed
Want more pics, just holler.
Attached Thumbnails DIY Cheap Mods-img_20110628_121202.jpg   DIY Cheap Mods-img_20110628_121251.jpg   DIY Cheap Mods-img_20110628_121259.jpg   DIY Cheap Mods-img_20110628_134055.jpg   DIY Cheap Mods-img_20110628_134040.jpg
Last edited by xraybox; Jun 28, 2011 at 12:54 PM. Reason: Added 2 closeups / note on washer for directional
Old Jun 28, 2011 | 04:43 PM
  #533
rsarno's Avatar
rsarno
Hello all! I have a small mod im about to make (if it can be called a mod?).
I dont have many windows to ride, so one of my nightly excuses to hop on the scoot is to head to dunkin donuts and pick up 2 large iced coffees for my wife and I.
They have a 4-cup holding eggcarton tray, i tear it in half and lower it into my saddlebag. I then prop up a sweater next to the large cups so they dont spill.
WELL, my idea is to hit the autopart store and pick up either a console type of thing that has 2 deep cup holders in it, or even 2 indevidual cup holders.
If i get the console thing my idea is to dremel off the section that has the cup holders.
If i get 2 individual cup holders, my idea is to find some sort of a spacer, and then maybe just use black electrical tape to join them (the spacer is so they arent too close). Once joined they cannot fall to the side because of either side of the saddlebags, and they cannot fall front/back because of the width of the 2 cups joined together.
The purpose for me doing this is because the eggcarton holders get moist from being left in the bike, and its a pain in the *** to tear them in the store each time, and i look like a weirdo doing it haha.
In total, this mod should be under $20 im thinking.
Thank you. Anyone else go on DD runs? hahaha
Old Jun 28, 2011 | 04:59 PM
  #534
Account Retired's Avatar
Account Retired
We made some cheap exhaust for my friend's old shovel out of the piping from a trampoline. Used a hydraulic bender and a plasma cutter, and welded it straight on to the heads.... We were young and stupid but it worked.
Old Jun 28, 2011 | 09:26 PM
  #535
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Thaks xraybox, that' should be good enough.
BTW I like that idea of the spacer on the mirror stem.
Its easier and cheaper than trying to find the extra deep Acorn nut I used on mine.
Great job.
rsarno,
Instead of buying a couple of cup holders and cutting them up why not just get a piece of plywood, any thickness will do.
Cut it to fit the inside of the bag, then use a hole saw to cut two holes for the cups and put 4" to 6" long carrage bolts in the four corners with the nice wide domed heads agains't the bottom of the bag (they won't over stress the leather that way) to hold it up off the bottom.
Then you can stand the cups in the holes to hold them securely when you need it.
Then when you don't need it, just tip it on its side so the wood is virtically oriented agains't the inside or outside of the bag.
It shouldn't take up much if any space laying like that, but you'll still have it in there whenever you need it.
If you have some scrap plywood, a can of black spray paint, and carrage bolts laying around it shouldn't cost more than a couple of hours work.
Old Jul 1, 2011 | 01:02 PM
  #536
2deuceguy's Avatar
2deuceguy
here is my contribution for the thread. this is a free mod if you're already buying cables or in some cases the stock cables may reach. i was switching all my cables to the diamond braid ones so i ordered all of them two inches over stock length then i routed them through the hole in the trees. i was running the stock length clutch cable like this before ordering the diamond braid. thanks for a great thread!
Old Jul 2, 2011 | 07:49 AM
  #537
Quadancer's Avatar
Quadancer
Nice look. Just a suggestion: where the cables touch/rub/vibrate against the risers or bars - eventually it could rub thru to the metal and scratch stuff. I just thought of a simple drop of "Shoe Goo" at the contact point might last forever and be unseen.
Old Jul 2, 2011 | 03:58 PM
  #538
2deuceguy's Avatar
2deuceguy
I just checked that out, got about 3 years and over 20,000 on it like that and no noticeable wear. U can see on the cable where it rubs but it's just a 1" dull spot. definitely something to keep my eye on though. Thanks for the suggestion
Old Jul 6, 2011 | 10:03 AM
  #539
W3HOG's Avatar
W3HOG
Stage II
My idea is somewhat similar but then again not. It does apply to carrying liquid in the bags. I want to insulate and water "seal" the inside of the bags, put in a drain, and "viola" Saddle Bag beer coolers!!!!! LOL
Dan
Old Jul 7, 2011 | 05:56 PM
  #540
kiwifulla's Avatar
kiwifulla
Dan
thats a lot better idea , mmmmm beer
