DIY Cheap Mods
Old Jun 2, 2008 | 10:06 AM
  #31
paulca's Avatar
paulca
Default RE: DIY Cheap Mods
Frank, thank you for thisexcellent thread. Your bike is looking great by the way - haven't seen your "new" signature until now.
Old Jun 4, 2008 | 06:51 PM
  #32
Nighthawg's Avatar
Nighthawg
OK, here's my easy way to make performance exhaust with your stock muffles.&nbsp\\; I have an 07 Night Train and was shopping for aftermarket exhaust upgrade because I just didn't have the sound and performance I wanted...from a Harley.
&nbsp\\;
I started by taking my mufflers off and punching the center baffle disk out...sounded good but didn't make the rumble I was looking for.
&nbsp\\;
After studing the construction of the muffler, I took a dremel and cutter wheel, from the aft end of the pipe, I cut around about 1/4 to 3/8 inch forward from the aft tip.&nbsp\\; Then I took a punch bar, stuck it in the forward end and gave it a couple of taps and the whole baffle assembly slid right out the back.&nbsp\\; Installed them back on the bike and cranked her up and blew the fiber glass out.
&nbsp\\;
I got the deep throaty sound I was looking for and I've ran her for about 750 miles and have noticable throttle reaction when I get on it and the fuel economy and engine running seem to be fine.&nbsp\\; It doesn't miss, spit or backfire.
&nbsp\\;
Ride on
Old Jun 5, 2008 | 05:29 AM
  #33
Scott.Harris's Avatar
Scott.Harris
6th Gear
You wanna see some cheap mods? Check out all these I did on my Fatboy. See if you can name them all!
http://cid-9a5eacb7dce06822.spaces.live.com/photos/cns!9A5EACB7DCE06822!115/
Old Jun 5, 2008 | 06:12 PM
  #34
HD32's Avatar
HD32
Anyone have any good ideas on how to decrease friction between my grip and handlebars?&nbsp\\; I have chrome spike grips that look great but the metal of the grips and the handlebars don't allow for a smooth throttle action.&nbsp\\; Kinda noisy too, when the grips starts squeaking.&nbsp\\; I've looked at the roller bearing kits that stick in the end of the handlebar, but they require cutting .5" of the bar off.&nbsp\\; Just wondering if there are any better ways to tackle the issue.&nbsp\\; Thanks.
Old Jun 5, 2008 | 06:33 PM
  #35
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
You might try to find some Teflon sheet, Teflon coated plastic sheet material or even nylon sheets.
You could slip a piece of that rolled to fit inside the grip and get it to stop sticking and making rattling noises.
Old Jun 6, 2008 | 11:12 AM
  #36
tjolley2000's Avatar
tjolley2000
Any one got a suggestions for making the ugly stock bolts all over the bike look better particularly the ones on the engine.
&nbsp\\;
I was thinking about getting some Black hottoppers, but a. they are expensive, and b. the look to be a gloss black from what I can tell and want them to match the wrinkle black paint on the engine case that is on the (07 FXSTC and I assume many others), that way they kind of disappear. Then do some kind of chrome look to the ones that bolt on chrome parts.
&nbsp\\;
Old Jun 6, 2008 | 11:34 AM
  #37
Have you considered trying some Rust-O-Leum wrinkle black paint?
Be simple and cheap, might not match perfectly, but be a lot better than the cad plated junk that's on there now.
Old Jun 10, 2008 | 08:17 PM
  #38
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
ORIGINAL: HD32
Anyone have any good ideas on how to decrease friction between my grip and handlebars?&nbsp\\;\\\\\\; I have chrome spike grips that look great but the metal of the grips and the handlebars don't allow for a smooth throttle action.&nbsp\\;\\\\\\; Kinda noisy too, when the grips starts squeaking.&nbsp\\;\\\\\\; I've looked at the roller bearing kits that stick in the end of the handlebar, but they require cutting .5" of the bar off.&nbsp\\;\\\\\\; Just wondering if there are any better ways to tackle the issue.&nbsp\\;\\\\\\; Thanks.
Put a thin layer of grease on the bar end under the throttle side, it will quiet it right down and it costs nothing.&nbsp\\; It did it and it works great.
Old Jun 10, 2008 | 09:54 PM
  #39
blk n wht hog's Avatar
blk n wht hog
Damn, Im too late CNC............I was gonna try and have you barred from tha competition!!!&nbsp\\; But he did say "cheap" mods, so that counts you out any way!!!&nbsp\\; Have a good one....
Old Jun 14, 2008 | 04:15 PM
  #40
beepo's Avatar
beepo
I've got one if you have a tombstone light out back.&nbsp\\; I hated the way the liscense plate just stood straight up, especially when I put on the solo seat and had a bare rear fender.&nbsp\\; A piece of aluminum flat stock from Home Depot and some bolts were all the supplies I needed to make a new bracket for mounting the plate.&nbsp\\; I just bent it to the angle I liked, drilled some holes, and installed it.&nbsp\\; I'll probably get around at some point to ordering the nice chrome piece that they sell to do the same job, but for now it's doing the job...
