Legend AirRide Vs. Progressive AirTail
Old Feb 21, 2006 | 12:07 AM
btmagician13's Avatar
btmagician13
Default Legend AirRide Vs. Progressive AirTail
Assuming I can pick up a Legend AirRide on ebay for less than $1000......should I get the legend system or the Progressive AirTail system?
Which one would be more reliable, comfortable for longer trips 2 up with luggage?
I am also considering the AirTails and just use the hand pump to keep the costs down.
Pro's/ Con's?
Old Feb 21, 2006 | 01:04 AM
kruzin's Avatar
kruzin
Default RE: Legend AirRide Vs. Progressive AirTail
I have the Legends on my 04 Standard and love it. Have been riding for two years and only had one problem, we had failed the pump. I contacted Legends and they were more that courteous and helpful. Sent me out another pump right away and I haven't had a problem since. I like the lower ride for in the city and when Krusin you can pump it up on the go to match weight and comfort of ride.
If interested I do have another pump as check valve (new) that I was going to use on another project but so far wife says no. Go figure!!
[IMG][/IMG]
Old Feb 22, 2006 | 11:50 PM
ChopperHammer666's Avatar
ChopperHammer666
Was the system easy to install? I was thinking about an air ride for my 06FXSTS. I like the look of the fender sitting on the tire when it's parked.
Old Feb 23, 2006 | 12:24 AM
kruzin's Avatar
kruzin
Not bad at all. The exhaust and seat will need to be removed. I the jacked the bike up to change out the shocks also installing the air hoses and wiring at that time. One thing I did do was to run the wiring through black shrink tubing. Did not heat it to shrink it, looks great and does a nice job of hiding the wires. Anyway the instructions were pretty straight forward and in the entire install took me about 4 hours. One thing I did change from the instructions is where I mounted the raise/lower switch. They will have you mount it on the billet housing holding the gauge on the right side of the rocker box. I found this to be rather inconvenient to adjust ride height when riding. I have since drilled a hole between the key switch and speedometer just to the left. Now I can operate the switch with my left hand while riding.
Old Feb 26, 2006 | 02:44 AM
porbagger's Avatar
porbagger
you need to look at the hi - lo air ride have it on my bagger and deuce works good go to bikerbuddypro.com
jam436
Air Suspensions
59
Dec 15, 2024 06:29 AM
DR. V-TWIN
Air Suspensions
Apr 14, 2018 08:46 PM
jgos929
Aug 20, 2015 08:54 AM
DR. V-TWIN
Air Suspensions
17
Sep 30, 2010 08:56 AM
94fatboy
Air Suspensions
Jun 21, 2010 07:01 PM
