Internal Throttle/Dual Cable
Old Aug 21, 2008 | 09:39 PM
dicolanl's Avatar
dicolanl
Stage I
Default Internal Throttle/Dual Cable
Looking for some advice about installing and internal throttle. my concern is that I have a 07 NightTrain and it has dual cable throttle. Any one installed internal throttle on a dual cable stock system? any recommended products?
I read the streamline has a spring which allows single cable setup on dual cable stock EFI.
Thoughts?
Old Aug 21, 2008 | 09:54 PM
crazybastid83's Avatar
crazybastid83
There is a heavy return spring on the throttle body itself. The DOT mandated dual throttle cables as a safety feature.
Buuut all of the internal throttle controls suck for everyday riding.
Old Aug 24, 2008 | 09:50 AM
rubiconMike's Avatar
rubiconMike
Why does the internal throttle suck for everyday riding? Just curious because I was thinking about installing one myself but if it's not worth it I would like to know now instead of learning the hard way.
Old Aug 24, 2008 | 12:43 PM
mimo's Avatar
mimo
Check out www.cyrilhuze.com he has internal throttle devices and also some pretty slick looking stealth handlebar controls... Not cheap thou... He is in Boca Raton Fl.
Mimo.
Old Apr 5, 2012 | 10:12 AM
Streamlinedesignsinc's Avatar
Default Internal throttle for everyday use....
I manufacture the only DOT approved internal throttle on the market, My patented throttle uses 6 bearings, 5 radial and one needle, It has a Spring return inside the throttle to help assist the Carb spring and allow for smooth return. It is manufactured out of 6061-T6 Aluminum then Hard coated for long life, we offer them in a new size that is specfic to fitting stock harleys with hand controls with swtiches. To install you dont need a welder, just a hack saw of cut off wheel, remove 4.75" off existing handle bar, remove return cable from stock set up, cut stock cable pull on throttle side, slide throttle into handle bars to scribed line on throttle, tighten down my wedge bolt (NO WELDING) run cable through center bolt/outer sleeve stop, attach to the internal cable pull and your done, VERY SIMPLE.
It retails for the 225.00 but if you give us your HDFOURMS.COM user name we will give you a 10% discount for being loyal to HDFORUMS.COM.
Give us a call at 1(855) SLD-BYAW or 1(855) 7932525
international 772 486 4996
email streamline954@aol.com
Old Apr 5, 2012 | 10:58 AM
SUUIE's Avatar
SUUIE
Not in my experience.
Old Apr 5, 2012 | 11:20 AM
Joe What's Avatar
Joe What
Old thread.. no problems with mine.
Old Apr 5, 2012 | 12:08 PM
Hogpro's Avatar
Hogpro
Former Sponsor
One of our employee's runs internal throttle and rides the bike to work every day. I have never heard him complain about it. It is a single cable internal throttle. Not sure on what brand he has.
travalab
May 16, 2017 09:04 AM
maximuswaximus
Jan 21, 2015 12:33 PM
8541hog
Mar 20, 2009 09:51 AM
kurtlange
Jan 24, 2007 03:01 AM
PIGLET 125
Aug 29, 2005 07:19 PM
