Removing broken reflector from front fork...
Old Mar 23, 2006 | 03:02 PM
vheflin's Avatar
vheflin
Default Removing broken reflector from front fork...
Has anyone ever needed to remove the small orange colored reflector off the front fork down near the wheel? If so, how did you get it off. It is very difficult to remove and I'm a little apprehensive about applying any type of solvents to it. Any ideas would be greatly appreciated. Mine has become damaged and I need to replace it.
Thanks
Old Mar 23, 2006 | 03:13 PM
05FXSTBI's Avatar
05FXSTBI
Default RE: Removing broken reflector from front fork...
I just yanked mine off, But it was around 90 degrees in the summer when I did it.
You can use a hair dryer to help loosen the double sided tape that holds it on. then yank it off.
You can use fishing line as a "Saw" and take it off that way also.
To clean off any sticky residue, use goo gone.
It will look alot cleaner with the reflector off. But if you chose to replace it , that is your choice.
Old Mar 23, 2006 | 03:15 PM
vheflin's Avatar
vheflin
Thank you, I'm off to get some fishing line and goo gone.
Old Mar 23, 2006 | 04:16 PM
DMSC's Avatar
DMSC
I use a product called "Goof-Off" (silly name). it works better than all of the other "Goo" remover products I've tried.
I just used a small screw driver to pry up the top corner of the reflector and applied the Goof-Off a couple of times...each time pulling the reflector off the fork a little bit farther.
Old Mar 23, 2006 | 04:17 PM
XARAN's Avatar
XARAN
Fishing line, hair dryer to heat it and WD40 will remove the glue residue.
Old Mar 23, 2006 | 04:56 PM
oldgeezer's Avatar
oldgeezer
I agree, WD40's the best.
Old Mar 23, 2006 | 04:58 PM
LOWTOW's Avatar
LOWTOW
Mine came right off with a little pull.
Old Mar 24, 2006 | 12:22 PM
FatBoy2five0's Avatar
FatBoy2five0
what xaran said
Old Mar 24, 2006 | 03:45 PM
RBPHAT03's Avatar
RBPHAT03
1st Gear
i took all the refletor stickers off my forks & tin with a heatgun . warmed them up and peeled them off.
Old Mar 25, 2006 | 03:52 AM
Original Junior's Avatar
Original Junior
From: The birthplace of our nation- Philadelphia proud!
Heat up with hairdryer & peel. Remove residue with 3M adhesive remover. Walmart carries it. Too easy.
zworld
Feb 5, 2012 10:30 AM
Rick7938
Mar 8, 2011 10:09 AM
de79
Nov 24, 2009 10:04 PM
99octane
General Topics/Tech Tips
Aug 18, 2009 10:26 AM
redmustang1990
Jan 5, 2009 02:14 PM
