Anyone experience this?
Old Mar 9, 2009 | 07:44 AM
MJHJEA's Avatar
MJHJEA
Default Anyone experience this?
I recently purchased an 06 softail deluxe and rode it the other day for the first time, wanted to check it out real good. The handlebars wobble pretty bad starting at exactly 40mph and subsiding at 35mph decelerating with hands off handlebars. Not really noticeable with hands on. Is this normal for the deluxe? Someone else said theirs did same thing from day one. My bike has stock front and is in mint condition with only 5,000 miles, so I'm very concerned. Will I be wasting $$$ taking it to Harley and finding out nothing is wrong? Appreciate any comments!
Old Mar 9, 2009 | 08:09 AM
Aaron01's Avatar
Aaron01
My 07 started doing the same thing and the steering head nut (not sure if that's the correct name) needed to be tightened. The book calls for using the "fall away" method which I never could get to work right. I torqued mine to 40 ft. lbs and all is well now. You will need a 1 1/2" socket though to fit the large nut.
Old Mar 9, 2009 | 08:13 AM
devo5566's Avatar
devo5566
Default stearing head bearing
I had that and it was just an adjustment on the steering head bearing
Try doing a search on this site. I saw a few threads that helped me out with that same problem
Old Mar 10, 2009 | 07:35 AM
tk353's Avatar
tk353
mine did that and it was front wheel bearings
Old Mar 10, 2009 | 09:48 AM
78fxs78's Avatar
78fxs78
Wobble is not good ! I agree the steering neck is probably too loose. You want it snug but not to hold in one position (off the ground). If too loose along time the bearing races get flat spots, then you tighten it up it'll feel rough. Wheel bearings and ballance can also be a prob but with only 5k its unlikely but go there if the first does'nt work.
Old Apr 3, 2009 | 11:02 PM
oct1949's Avatar
oct1949
agree with 78, probably need to lube and check steering bearings.. wouldn't think the wheel bearings with that low of miles unless someone really maintained poorly.
Old Apr 3, 2009 | 11:19 PM
SD Night Train's Avatar
SD Night Train
no one has mentioned this but a good thing to check is your tire pressure
Old Apr 3, 2009 | 11:36 PM
Mordrapheus's Avatar
Mordrapheus
I haven't had that yet but this is like the third or forth thread I have read now in the last few days lately
Old Apr 4, 2009 | 09:38 AM
mgmmgm's Avatar
mgmmgm
Thumbs up +1 on air psi
I agree, air pressure in the tire is a possible cause; not to say that checking bearings is not a bad idea. My Fatty front tire will wallow around a bit if I do not watch tire pressure so I heck before each ride and have tire pump handy for that.
Ride Safe,
mark
CrazyBones
Sep 18, 2015 07:58 AM
Dancemax
Jun 8, 2014 08:28 AM
commander112
Jun 11, 2007 03:52 PM
ROLAND FLAGG
May 19, 2005 12:33 PM
pococj
Jan 17, 2005 07:23 PM
