Lube and the Three Holes
Old Apr 3, 2009 | 08:30 AM
hgiles's Avatar
hgiles
Default Lube and the Three Holes
Under typical circumstances I don't need to ask this question. But where are the entry and exit locations? I found one (primary), but can't be sue on the other two? Any help is appreciated.
Thanks
09 Softail Cross Bones
Old Apr 3, 2009 | 08:34 AM
DyNaBoB's Avatar
DyNaBoB
tranny is between the shocks and the oil is a bolt on the right side swing arm.........just follow the oil line down from the tank
Old Apr 3, 2009 | 08:39 AM
Mordrapheus's Avatar
Mordrapheus
oh this is just impossible to resist
well I am happy that you were able to devine the primary hole, though lubing that may get your ears talked off, now from the dentured orifice head straight south, you may want to use your finger to trace this, keep going down in between the 2 mounds, when you hit the belly buttong keep going down, you might reach a fury section now, but persist in your southward journey.
somewhere, I repeat, somewhere in the area between as far south as possible and before you circle around and head north again you should be able to locate the other 2 holes, lube these well, and you should be set.
It is very important that you stay straight on your line south, otherwise you might end up following one of 2 stuts south and miss what you are looking for.
Old Apr 3, 2009 | 08:43 AM
hgiles's Avatar
hgiles
Yeah, I was hoping a bit of a sexual twist would get some attention! 4 minute response time!! That sounds about right, eh?
Old Apr 3, 2009 | 08:48 AM
Mordrapheus
lol
yeah
Old Apr 3, 2009 | 10:01 AM
05softaildeluxe's Avatar
05softaildeluxe
great sexual thoughts and bikes the best !!!!!!
Old Apr 3, 2009 | 10:38 AM
kromdom's Avatar
kromdom
hope below helps (courtesy of soos)
Old Apr 3, 2009 | 02:13 PM
hgiles's Avatar
hgiles
Coolness! Will tackle that tomorrow morning!
ElectraJim
Aug 26, 2016 04:13 PM
Yankee Dog
EVO
Jun 11, 2015 01:36 PM
gasforblood
Sep 12, 2012 09:25 PM
03TC88
Jan 7, 2012 04:20 PM
n2xlr8n
Oil Archive (no new posts)
Feb 24, 2005 08:28 AM
