Slip On Muffler Debate
Old Apr 6, 2009 | 05:44 PM
  #31
edeluxe07's Avatar
edeluxe07
Originally Posted by tmcgeesr
Unless you change the Intake Tract & Filter to something other than stock your OK. I hate to say it but, my experience with dealers who just want your money isn't good. Most of what they tell you is BS.
My dealer is telling me they no longer recommend the Power Commander. They are now pushing the Harley Race Tuner. It costs $400 + and requires Dyno time for another $375. It is not part of the bike and is only plugged into your ECU during the tuning process. It has your serial number programmed in. Every time you do anything to your bike you need the device and more Dyno Time. Theoretically you must carry it with you in case anything goes wrong. Its all about getting your dollar!
This is one of the biggest reasons I just installed the Thundermax ECM w/autotune....runs great with the new pipes.... now I can tune the bike myself....no more dealer, yeah!
Old Apr 6, 2009 | 05:58 PM
  #32
llbigbird's Avatar
llbigbird
Originally Posted by Cheesecake
Newer Harley's have an ECU that reads the A/F ratio via O2 sensors.... the ECU then adjusts the A/F ratio to compensate for small changes in Airflow etc....
A Major Motorcycle Magazine has actually published an article stating that with the new Harley fuel injection system, you can install a set of high flow pipes and a high flow air cleaner and that the stock system will compensate for the changes....
If he is only going to install pipes, he has nothing to worry about
CC
I stand corrected and have to thank you for giving me info I may need in the future. Thanks for not thinking I was being a "know it all"
Old Apr 7, 2009 | 07:40 AM
  #33
oct1949's Avatar
oct1949
Pipes only, install and ride. will still be epa stock lean though.
pipes and air cleaner, then u will need some kind of fuel Mgt system.
Old Apr 7, 2009 | 07:58 AM
  #34
tmcgeesr's Avatar
tmcgeesr
The new PCV has an optional feature called the Auto Tuner. It consists of a different oxygen sensor and wiring. It automatically adjusts your bike to whatever you do. Good only on the the 09 Harley. When I installed my PCV it wasn't available yet so I went the fuel map route. I plan to look into to it down the road. According to my PCV service center its only an oxygen sensor and some wiring that has to be routed to the power commander.
Old Apr 7, 2009 | 06:08 PM
  #35
Chooch Oley's Avatar
Chooch Oley
From: Oswego NY..."a little town, a lotta assholes "
I might just as well put the slip ons on and see it runs any different. If it does start poppin and fartin then I guess I'll make the other necessary changes.
Chooch
Old Apr 7, 2009 | 06:54 PM
  #36
RDKingRider's Avatar
RDKingRider
Just go ahead and buy them and put them on, after you ride it for awhile you will be able to tell if you need to do anything else to the intake.
Old Apr 8, 2009 | 01:02 AM
  #37
dantoniov's Avatar
dantoniov
Stop nibbling on the bait and take the hook hehe. You're gonna end up doing it anyways. Well, I did a lot of research myself and given that the bike I purchased was already too expensive to "not remap" I waited until I had enough $$$ to do the stage 1 as well.
From what I read you can probably get away with just putting on slipons but that's not to say you didn't just relieve a lot of back pressure changing how your engine performs.
This can be noticed (probably too late) when your pipes change color, back fire (pops on dcel) etc. If you can live with that, go for it.
As for the long term affects of not remaping, no clue.
Old Apr 10, 2009 | 03:43 PM
  #38
Chooch Oley
WELL, I did it ! I bought 'em today. V & H Straight Shots w/Quiet Baffles. Put 'em on tomorrow. Independant Shop. Guy was cool and said try them without the fuel pak and see how it runs . Didn't try to sell me any extra's..................I'll let you know how they sound !!!
Old Apr 10, 2009 | 09:13 PM
  #39
rickb's Avatar
rickb
I rode mine that way for about 3k miles never noticed anthing bad. it was really lean. I did the filter and everything at the 5k service. It was like riding a different bike. Ran much stronger after.
Old Apr 10, 2009 | 11:25 PM
  #40
malo's Avatar
malo
I called rush, and had a pretty educating conversation. I bought the slip ons. They say just changing the pipes or changing to their slip ons will make the bike sound better but not give you better performance. He said you will think you are getting better performance because it will sound better, but you are not. To get better performance you have to add the extras. I put on the slip ons, and love them. Bike sounds great, and no problems.
