lowering bolt install?
Old Apr 8, 2009 | 08:29 PM
Dustmaker's Avatar
Dustmaker
LMAO....You guys would not believe how I did mine!
I used a floor jack, 2x4, deep well socket and a metal pick.
Placed the deep well socket(don't remember the size, but large enough that the shock eye fit inside) on the floor jack. Then placed shock with eyelet inside socket on jack. Cut the 2x4 long enough to reach the center I-beam in garage. Place the board on top of the shock stud and jack up til you have tension on the shock. You only need to compress teh spring a very little. There is a small clip that has to be removed and the shock comes apart!
Make sure you set all of your parts on both shocks the same. Count threads. Also use plenty of loctite when putting them all back together.
Really not that hard!
Old Apr 8, 2009 | 08:53 PM
Blk and Chrome's Avatar
Blk and Chrome
LMAO, that you should have a vidio of, sorry man, but the picture in my head of you doing that is funny
Old Apr 8, 2009 | 09:35 PM
Dustmaker's Avatar
Dustmaker
Buddy came over to watch because he said there was no way I could get it done without a press...lol Showed him!
Old Apr 8, 2009 | 11:32 PM
Called2Duty's Avatar
Called2Duty
I had my lowered and inch and a half with bolts at the dealer also. took them an hour cost 70 dollars for the bolt kt and i believe it was 50 for the labor, unfortunatly no bar next door so I had to wait
Old Apr 9, 2009 | 05:40 AM
dc4stroke's Avatar
dc4stroke
I haven't done mine yet but I used to use a set of clutch plates with threaded rod as a shock press. I'll do mine when I find my homemade press. I know it's here somewhere.
Mrsofty1340
May 11, 2017 12:59 AM
IronAK
Mar 29, 2013 08:04 AM
neocontra
Jan 3, 2010 06:55 PM
ski917
Jul 24, 2009 11:48 AM
jd8181
Jul 10, 2009 05:05 AM
