lowering bolt install?
Old Apr 7, 2009 | 09:19 PM
jcmer22's Avatar
jcmer22
Default lowering bolt install?
so i bought some lowering bolts for my 08 train and want to know what i need to install them. im gonna be picking up a jack and i have the usual basic hand tools. do i need anything special for disassembling the shocks and if so were i do get it or make it? and they didnt come with install instructions, anyone know were i can get a set. thanks in advance, john
Old Apr 7, 2009 | 09:26 PM
Blk and Chrome's Avatar
Blk and Chrome
You will need a press to change them as you have to compress the spring to take the shok apart or take them to an indy or dealer and they will charge you to install them.
Old Apr 7, 2009 | 09:32 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
you will need a press for sure. go to the arlen ness web site. they have install instructions there. after you install dont forget to adjust dampening as ride will be horrible if not adjusted. and prepare to get a hernia to loosen up side bolts to frame as HD super torqes them in...good luck...
Old Apr 7, 2009 | 09:45 PM
jcmer22's Avatar
jcmer22
how do i adjust the dampening? and how much should i adjust it?
Old Apr 7, 2009 | 09:59 PM
BLKnCHRME09Deluxe
your gonna need a spanner wrench to adjust shocks for dampening. i had a indy who adjusted mine to the stiffest setting and ride is just fine with no bottom outs. my weight is aroung 220lbs....i did the bolt install but had a indy who did my adjustments
Old Apr 7, 2009 | 10:09 PM
DyNaBoB's Avatar
DyNaBoB
go to a local indy to put the bolts in Dont do them yourself unless you want to lose an eye.......indy will install them for around 25 bucks.............then once you install em play with the dampning with a spaner wrench from hd (10) bucks............i use the wrench they give you to change a blade on a 4 in grinder......shhhhhh my little secret
Old Apr 7, 2009 | 10:13 PM
jcmer22's Avatar
jcmer22
well i have access to a drill press. will this sufice?
Old Apr 7, 2009 | 10:20 PM
BLKnCHRME09Deluxe
sounds like a $100 bucks for bolt install could be your best bet. screw the headaches. drive your ride to the indy then a couple of hours pick it up and ride. or remove shocks urself and indy will install bolts for $25 buck then put back in. When i did mine, i wished i payed the $100. shocks were a PITA to remove. very tight fit. sounds like your not to familier with shocks but i could be wrong.
Old Apr 7, 2009 | 10:23 PM
DyNaBoB's Avatar
DyNaBoB
nooooooooooooooo way dont do it..............is your sight worth 25 bucks...............they do sell a kit that just screws to your stock bolts but would you trust it for the money..................i went with wild one bolts, 50 bucks,indy install 25..........so for a safe lowered ride for 75 bucks....you cant beat it.................imo the progressive 422s dont ride that much better............plus you can put that money toward air ride
Old Apr 7, 2009 | 10:25 PM
DyNaBoB's Avatar
DyNaBoB
sounds like a $100 bucks for bolt install could be your best bet. screw the headaches. drive your ride to the indy then a couple of hours pick it up and ride. or remove shocks urself and indy will install bolts for $25 buck then put back in. sounds like your not to familier with shocks but i could be wrong.
+1 dont play with shocks if you dont know em...........i had the bolts put in wile i went next door for a beer and they wur done and went home and installed never been happier.......oh and i can see..............
