HD Run/Turn/Brake Module
Old Apr 17, 2009 | 03:08 PM
Mike NY's Avatar
Mike NY
Default HD Run/Turn/Brake Module
I installed one of these last year and all is well. I just never noticed that the Front Turn lights stay on as Run lights also. Is this the way it's suppose to be?
Mike
NY
Old Apr 17, 2009 | 03:23 PM
Cheesecake's Avatar
Cheesecake
some are set up that way...
it's probably depends on who's unit you have
CC
Old Apr 17, 2009 | 03:40 PM
Archer1968's Avatar
Archer1968
if its stock its supposed to be that way.
Old Apr 17, 2009 | 05:07 PM
jimmers1817's Avatar
jimmers1817
Never took notice myself. Put one on the wife's Deluxe last year and thought it was just for the back lights. If that's the case, it's an extra plus.
___________________
2008 Heritage Classic: His
2008 Deluxe: Hers
Old Apr 17, 2009 | 05:35 PM
BTrain's Avatar
BTrain
Nope, Harleys come from the factory with the front lights wired as running lights, as well as turn signals. The module has nothing to do with the front lights.
Old Apr 17, 2009 | 07:50 PM
Mike NY's Avatar
Mike NY
Interesting, for some reason I thought they weren't on when the bike was stock without the module. Maybe I'll disconnect the module and see what happens.
It's the module HD sells.
Thanks,
Mike
Old Apr 17, 2009 | 09:43 PM
schumacher's Avatar
schumacher
pssssst....yer front turn signal lights are always on regardless
Old Apr 17, 2009 | 09:54 PM
snip0721's Avatar
snip0721
yep..their right. front are a dual element bulb from the factory. run/turn. the rear are a single element, and thats what the module affects. steve
Old Apr 17, 2009 | 09:55 PM
Whoad00d's Avatar
Whoad00d
+1 on always on irregaurdless 8*) hope you understand just relocate the fronts if you don't like now.
Russ
Old Apr 17, 2009 | 10:15 PM
WarriorHD's Avatar
WarriorHD
I always knew my front headlight was a running light...never realized the turn signals were as well...
