The famous bottom bolt .
I have an FXST, and different forks, but those stupid bolts put me in a loop, search the forums, the maker 'SHOWA' is actually using Metric bolts !
Not only this, but you will need a torque driver socket to get that bolt out or it will just rotate with the internals as in my own self sad execuse for a wrench case .
what's the bottoming cones? I have no service manual, but I do however have it back together...
I lowered my wife's Dyna using the progressive kit, instructions weren't brilliant but I managed to work through it, I did a search on here before to find out how much oil before I started, I have taken the bike out myself and it has made the front end seem a bit heavier when cornering at slow speeds but i should imagine lowering the bike must change the rake slightly
