odd hot engine starts
Old Aug 3, 2009 | 06:14 PM
Mark g's Avatar
Mark g
Was it hotter then it's been lately?
might have just been loaded up.
LH's Avatar
LH
Originally Posted by schumacher
last q....
when I turn the lock to on, the engie makes a whirring noise (like it's EFI) for a few seconds and then quits.
What the hell is that?
Do you have a manual reserve petcock on the bottom of the fuel tank that you turn on for reserve fuel?
Old Aug 3, 2009 | 06:21 PM
m i k e's Avatar
m i k e
mine does that too,gunna try the ol start asap after fuel up
Old Aug 3, 2009 | 06:48 PM
schumacher's Avatar
schumacher
yeh, it has a petcock
Old Aug 3, 2009 | 07:12 PM
dennyo's Avatar
dennyo
I use the Stock Plugs.... 6R12
They Run Cooler
I've tried all the other 1's . and . the Stock 1's Work Best Fur me...
Old Aug 3, 2009 | 07:24 PM
Blk and Chrome's Avatar
Blk and Chrome
Mine does the same every now and then. I would just try a new set of plugs, but could also be a vaporlock type of problem. My friends does it too and his is all stock.
Old Aug 3, 2009 | 08:40 PM
KumaRide's Avatar
KumaRide
Other things that could cause this-
Bad gas - low octane?
Marginal battery or starter. Week ground or battery connections
Lifters bleeding down. Some people add travel limiters, usually cammed bikes though.
If I start mine in 1st with clutch pulled in, it does it from time to time. I make it a point to start in neutral and it does not happen. Makes it a little easier on starter and battery to kick motor over...
Old Aug 3, 2009 | 10:27 PM
dusty2221's Avatar
dusty2221
It's yer flux capacitor.
Old Aug 4, 2009 | 12:07 AM
FLSTC4ME's Avatar
FLSTC4ME
Mine does the hard start too. It's also carbed. I don't know what does it but it's aggrevating. After you have it hot and it starts doing it, I have found out to just give it just a little throttle and it will fire up everytime and not burp and fart like you are talking about. I guess that's what you get when you mess w/ factory settings.
Old Aug 4, 2009 | 12:31 AM
oct1949's Avatar
oct1949
done it a few first K. after stg 1, SERT, & dynoed , very seldom, now since cams & another dyno, not yet.
