Auxiliary Brake Light/Turn Signal Kit
Old May 4, 2005 | 10:00 PM
Kess's Avatar
Kess
Default Auxiliary Brake Light/Turn Signal Kit
greetings - I bought the Auxiliary Brake Light/Turn Signal Kit for my 05 softail standard. (Turn signals work in connection with brake light) It seems like a breeze to install but the first step in the directions is to disconnect the battery. Do I REALLY have to do this step?
Old May 4, 2005 | 11:17 PM
TxMoores's Avatar
TxMoores
Default RE: Auxiliary Brake Light/Turn Signal Kit
If you do not disconnect your battery you could accidently short circuit the brake / turn module, or damage some of your bike's electronics.
(FYI... When I installed my Kuryakyn Panacea LED brake light / turn signal system I was going to disconnect my battery, honestly I was going to... but I didn't and I didn't fry anything, this time... 0
Old May 5, 2005 | 12:14 AM
VegasFatSE's Avatar
VegasFatSE
I did not undo the bat either. It took me a whole of five mons to remove seat plug in module. I also installed clear lens with red LED lights. Inside the 5 min window.
Old May 5, 2005 | 01:29 AM
Lovetoride's Avatar
Lovetoride
I wouldn't risk spiking your ECM or another module. It takes 20 seconds to unhook your battery...
Ryan
Old May 5, 2005 | 10:31 AM
Kess's Avatar
Kess
Thanks for the info!
jjaacooper
Mar 22, 2012 09:57 PM
twofish
Mar 13, 2012 10:54 AM
1ADAM12
Feb 18, 2008 04:49 PM
JBBOOKS
Sep 8, 2005 09:54 PM
tomram
Aug 29, 2005 04:44 PM
