what is the
Old Dec 2, 2009 | 09:15 PM
hspring03's Avatar
hspring03
As far as air cleaners go, it has to with the bolt pattern.
To put a CV aircleaner on an S&S carb, you will need an adapter plate and a new choke **** if you were running the tear drop.
Kuryakyn sells the adapter
Old Dec 2, 2009 | 09:47 PM
mac0478's Avatar
mac0478
Is there a noticeable improvement in performance when changing from the CV to the S&S without any other modifications? How does the mikuni carb compare to the S&S in terms of tuneability, economy and serviceability?
Old Dec 3, 2009 | 10:26 PM
Northside's Avatar
Northside
Short answer: no.
As I stated before, it's hard to beat the stock 40 m.m.CV on a stock or mildly hopped up motor. The S&S is a great carb, the Mikuni is my personal preference on a hot rod motor. The 120 JIMS motor comes with a bigger CV. It's 51m.m. so those are pretty good carbs. There has been a little mis information posted in this thread. The stock CV is 40.mm. It has an accelerator pump. The carb has a vacuum operated slide which controls the amount the carb opens regardless of the butterfly opening. The jet needle is attached to the slide. You can get a 44m.m. CV too but it's not for a stock motor. Several sizes of S&S are available for different size motors. Mikuni makes a 42HSR for stock motors, it's a great carb, but it won't help a stock motor gain power, it's for big bore cammed up, higher compression bikes. The Screamin' Eagle and Ness air cleaners are easily adapted. You can spend the money on the S&S but I don't think you'll gain anything but a cool aircleaner cover. There is a kit to adapth that S&S cover to the stock CV. There are alot of air cleaner option for that CV.
Trmeans87
EVO
22
Apr 22, 2013 02:27 AM
sandyreilly
Jul 19, 2011 09:39 AM
michaelbarry
Jul 18, 2007 03:19 PM
stone_rider420
Apr 14, 2007 11:03 AM
93HD
Exhaust System Topics
Apr 10, 2006 11:56 AM
