From: LI, and New York, NY -- N 40 44.985 W 73 00.910
Originally Posted by tk353
I got the Gerbing liners and the remote mount thermostat and the boot liners and the gerbing jacket. the jacket was 300 then 200 and then 129. here is how i mounted the thermostat and i use the connector from the front of the seat so i can hide it in the summer. http://www.heatedclothingoutlet.com/...%20liner.shtml
I am going to do a permanent install (similar to tk353, but on top) on the center console of the Electra Glide after I receive my perm dual thermostat around Jan 4th. I got it for 30% off at my local stealership.
for now I have the Dual Temp Portable setup.
I run the battery connect out the left side by my leg, and under the fuel tank. When not in use it tucks up and away. I zip tied the controller wires to make it less of a big tangle.
The G3 Gloves and Gerbing Jacket Liner are excellent.
Excellent info guys, do you really think that I will need a controller when just using the gloves? Doesn't get too bad cold here in North Ga. but my hands are out from the windshield and they are all that get cold. I love the gloves, fit, look etc. but want to do it right since my wife forked out the $$$ for the heated ones.
Thanks
Tim
You really only need one controller for three motorcycles or for ten, just make sure you get the dual controller. If you have gloves and a jacket then you should already have two fused power kits. Just get you on more of those and rig the plug in a similar location (one power kit per bike) on each motorcycle. If anyone else is considering heated gear, just remeber Gerbings makes the HD stuff, but HD only warranties for a year. Gerbings has a lifetime warranty. Just a thought...
you need a controller. whether you need a single or a dual is up to you. i run the glove liners and the long sleeve jacket liner with my leather jacket over it and only need the one to set the hands and body to where i like it. my insoles need to be hotter and i should get another control for them. if i use all 3 on one controller my feet are cold unless i wear thermal socks. get the dual controller and save the expense of getting another later if you feel you need to have something adjusted more than the other. Like i said the glove liner and the jacket liner work fine on one controller for me. I also wear the harley non heated liners they sell for $10 and then put the heated glove liner over it so as not to burn the back of my hand
Yup, gonna trailer down to somewhere in Florida, unload and ride down to the Keys.
plan to meet a couple of my Snobird buddies for the ride. . . . the older I get the less of this snow & cold I like. . . . . . was gonna do it last year, but had a Hernia repair instead.
My on/off switch that came with the gloves fell of in a restaurant within the first two weeks. It never reappeared. I haven't used one since. If it gets hot enough to 'burn my hands' then I don't need the gloves and can get by with my regular riding gloves. If I need to use my heated gloves they never get that hot.
