Pipe install issue on 09 Fatboy - passenger footpeg
Old Dec 29, 2009 | 02:26 PM
FrankT's Avatar
FrankT
Default Pipe install issue on 09 Fatboy - passenger footpeg
Hi Guys,
Getting ready to install VH BSS pipes on my 09 Fatboy, but I cannot seem to get the right side passenger foot peg bolt to come off. This needs to come off in order to install the pipes, but it does not want to move. I am using a T-50 torx allen type wrench because I cannot use the socket T-50 due to the fact that the bolt is recessed and the socket is too big (it is hitting the housing on the footpeg assembly). Does anyone know if the footpeg bolts are reverse thread or are they simply just put on with locktite from the factory? Any advice from someone who has done this before would be appreciated! Thanks and seasons greetings!
Old Dec 29, 2009 | 02:36 PM
mke125125's Avatar
mke125125
they are not reverse threaded. the factory uses some sort of crazy strong locktite. just get something on the wrench that will give you some leverage and apply steady pressure. it will break loose no prob.
TerryJ's Avatar
TerryJ
6th Gear
They are standard thread. I broke mine loose with the peg itself but you will more than likely have to use brute force. Go to a local autoparts store and buy a cheap extended reach t50 socket.
Old Dec 29, 2009 | 02:39 PM
Maimas's Avatar
Maimas
That is definately a bitch to get off. Also, if you are removing the OEM bracket, you will need a shorter bolt to remount the peg bracket. Dont try cutting down the existing bolt, because its not threaded all the way to the head and you'll bottom out before its tight enough. You'll need a bolt about an 1 1/2" shorter.
Old Dec 29, 2009 | 03:24 PM
aviator's Avatar
aviator
yep - they are hard to get off.
replace the OEM bolts with allen head cap screws - you'll thank me next time you decide to take the pegs off.
Old Dec 29, 2009 | 04:38 PM
Ballsout's Avatar
Ballsout
On my 09', the left side was torx, the right side was allen head. Go figure that one MOCO
Old Dec 29, 2009 | 05:17 PM
sancho_panza's Avatar
sancho_panza
Frank, go to Autozone and buy their pack of extended reach torx 3/8" drive sockets (better than my Craftsman set, which was three times the price). Use a 1/2" to 3/8" adapter, and hit that bolt with a long 1/2" breaker bar and extension. That's what I did on my right passenger mount, and it came off with very modest effort (my breaker bar is l-o-n-g).
Ron
Old Dec 29, 2009 | 06:03 PM
FrankT's Avatar
FrankT
Guys,
I got it off. I was able to use the T50 torx "allen type wrench", put the long end into the recessed peg support bracket, and use a piece of 1/2 black iron pipe to put over the short end to give me the leverage that I needed to break it free. Thanks to all of you for your advice.
Frank
Old Dec 29, 2009 | 06:23 PM
Barnettbill's Avatar
Barnettbill
For future reference, you can use a hair dryer to soften up the locktight on bolts and screws. Makes it alot easier to remove.
Old Dec 29, 2009 | 07:15 PM
snook592's Avatar
snook592
Oh sure wait 'til he's done then give him that handy piece of info. ...... lol
