Rear fender screws
Old Jan 7, 2010 | 06:37 AM
Jholbein's Avatar
Jholbein
6th Gear
Default Rear fender screws
Can somebody help me. I have a hard time to remove the screws that hold the rear fender, since they are coated with some kind of screw lock. Is there any easy way, instead of brute force and stripping the screw heads?
Old Jan 7, 2010 | 06:45 AM
draftsman's Avatar
draftsman
THey are tight. I have had a problem with them too, but have never had any strip or break on me.
Old Jan 7, 2010 | 06:49 AM
twisted125's Avatar
twisted125
Brute force worked for me, never felt like they wanted to strip you just have to break em. I layed a thick blanket over the rear trying only to expose the part I was working on in case the wrench broke free and careened towards some paint while dropping a nut trying to loosin them.
Old Jan 7, 2010 | 07:36 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
"Careened towards some paint"....I like that line. Man it seems everything I do on my bike something tries to careen into my derned paint!!
OP...Use a longer ratchet on those bolts.
Old Jan 7, 2010 | 08:24 AM
boosteddelslow's Avatar
boosteddelslow
I have found that the best way to get them out is alot of brute force and ignorance!! LOL Them things are tight.
Old Jan 7, 2010 | 08:27 AM
fatbill's Avatar
fatbill
5th Gear
Red loctite. Heat helps. Be careful how you ask the next question.
Old Jan 7, 2010 | 08:33 AM
tlb's Avatar
tlb
try heating them with a soldering iron
Old Jan 7, 2010 | 08:45 AM
aviator's Avatar
aviator
good tip - I never thought about a soldering iron. I used a hair dryer.
Old Jan 7, 2010 | 08:55 AM
RocketRocker's Avatar
RocketRocker
I would suggest a "cheater bar" too....just grab a piece of EMT pipe preferably around 2-3' and that will give you plenty of leverage. No need to heat it up with the cheater bar.
Old Jan 7, 2010 | 09:14 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Excellent idea there TLB!
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
