Need Help removing bolt from softail shock
Old Mar 7, 2010 | 01:28 PM
GHNighttrain's Avatar
GHNighttrain
5th Gear
Default Need Help removing bolt from softail shock
doing a lowering kit on a 2004 night train and cant get stock bolts out of shock. using ebay lowerig botls
Help
Old Mar 7, 2010 | 02:00 PM
hawaiian Dragon's Avatar
hawaiian Dragon
Did you Compress the shocks first? I believe that is the way you have to do it.
Old Mar 7, 2010 | 02:01 PM
Bugsplat's Avatar
Bugsplat
Are you able to get the wrench the bolts? One guy on the forum suggested that you raise your bike, get the wrench on the bolt, then lower the bike - the weight of the bike will loosen the bolt. I used the snap-on adapter that is called out in the service manual - this worked great and I was able to torque it back on per spec.
Old Mar 7, 2010 | 02:02 PM
JimStro16's Avatar
JimStro16
I used them on mine and had no trouble. Just used a wrench and vise to grip the shock and they came out. It probably helped that I did it on the bike when it was brand new. I remember I had to use a press to get the new ones back in.
Old Mar 7, 2010 | 02:03 PM
GHNighttrain
5th Gear
got the shock off but cant get the bolt out of the shock. it unscrews to a point then stops.
Old Mar 7, 2010 | 02:04 PM
JimStro16's Avatar
JimStro16
DId you take them out of the bike or are you trying to do this with them mounted still. I removed mine from the bike first and it was very easy
Old Mar 7, 2010 | 02:05 PM
JimStro16's Avatar
JimStro16
Try compressing the spring first with a press to releive the tension then take the bolt out
Old Mar 7, 2010 | 02:21 PM
Bugsplat's Avatar
Bugsplat
Sorry, I misunderstood your question. Sounds like JimStro16 has you covered.
Old Mar 7, 2010 | 11:52 PM
kiwideuce's Avatar
kiwideuce
you need a press, to to compess shock to remove pin,so you can change bolts,not sure of the procedure,but i will be lowering my bike with the bolts very shortly, so been doing some research,if you have shocks out,hardest part done apparently,right hand shock a real hassle!! then you need a press to change bolts is my understanding!
Slamed Slim
Jan 21, 2015 08:43 PM
J-Dog
Jun 10, 2011 11:57 PM
GEESE
Jul 25, 2010 09:34 AM
Hagar the Horrible
Nov 1, 2008 09:25 PM
singlepin
Mar 13, 2008 08:59 PM
