Fork tubes!
Old Mar 19, 2010 | 10:09 PM
BoomerBob's Avatar
BoomerBob
Check out these two video's before you get started.
http://www.youtube.com/watch?v=kZGHZFLk23k
http://www.youtube.com/watch?v=RtwCNSclmYs
Old Mar 19, 2010 | 10:37 PM
wiseguy2day's Avatar
wiseguy2day
Good timing, I'm lowering my front end next week!!
Old Mar 20, 2010 | 02:25 AM
RedDeluxe2008's Avatar
RedDeluxe2008
I am replacin my stock sliders to chrome sliders. Thanks for all you guys input now I know what Im missing....fork oil.
Old Mar 20, 2010 | 07:54 AM
FastHarley's Avatar
FastHarley
Former Sponsor
I have not read what you are doing but a word. Of course if you have a spring preload spacer, it must be cut down the exact length difference between the two fork tubes. Do not take a chance and measure first. Just because the vendor said 2" does not mean 2". This I know from experience, so measure. I am sure you already know this but just checking. If there is no spring preload spacer and your fork spring hits the fork cap than you must buy the proper spring length (using a spring preload spacer for adjustment) to work also upgrading your spring value while at it. Good luck. PS make sure the ravel/stroke is not longer than the distance between the fender to the bottom of the triple tree or bad things will happen.
mmullins2000
Oct 14, 2014 04:50 PM
S.D.M.F
Oct 24, 2013 03:07 PM
cripple
Jan 20, 2013 05:50 PM
karlkcfi
Apr 1, 2012 03:42 PM
DWhite
Apr 22, 2008 03:52 PM
