J&M MHAS-2008 Speaker Review
I found the speakers brand new on EBay for $360.00 (a great deal, thats why I bought them). Suggested retail is $499.00, but you can find them all over for around $420.00.
About the speakers:
These self amplified powerhouses are virtually hand built in our factory in Tucson. The amplifier circuits that are installed into the base of the speaker housings now put out well in excess of 40 watts each channel and are sealed in epoxy to provide complete weather proofing. (this power output increase and the noise filter being completely encased inside the housings is what differentiates the MHAS-2008’s from our previous MHAS-2005 speaker sets, along with the lower price). Not only powerful, the amplifier circuits have been specially tuned for the high gain levels necessary to amplify even the smallest of Walkman/MP3-type or portable satellite radio music devices. Left speaker side mounted volume up/down control switches provide for ease of use and convenience while riding. The speaker cones are also waterproof and will provide many years of service without damage from the weather. A top quality chrome finish is applied to the speaker housings as well as the mounting brackets for beauty and durability. The speakers connect directly to your bike's 12V electrical system (no batteries are needed except for your personal music device) and all necessary wiring, mounting hardware and installation instructions are included.
The installation was relatively simple. J&M provides good if somewhat basic instructions. All of the electrical connections with the exception of the 12 volt power wire are plug and play. The hardest parts are deciding where to hide the extra cable and deciding where to take the power from.
I hid most of the extra cables in the front fork tins (well Duh!). I took several tries to get them bundled up properly with tie wraps so they would fit in with the proper amount of slack.
Power was a little harder. J&M recommends using a switched power supply (so you don't run your battery flat), but they don't tell you which one. After inspecting a softail wiring diagram and discussing it with some of my more knowledgeable friends I decided to use a crimp splice on the orange and white accessory wire.
The speakers themselves seem to be well built and the chrome was nearly flawless. The kit included all needed parts with the exception of a splice crimp. (I bought a pack at Lowe's for $2.98.)
The speakers mount to the HD hand controls with included chrome mounts. Mounts seem very strong with no play or vibration.
I used a Sansa Fuse as my MP3 player.
The Good!
The speakers worked perfectly first time out. The music sounded awesome accompanied by the rumble of my Thunderheader. Maximum undistorted volume is very good, bordering on painful. ( After 2 hours of solo riding blasting classic rock at near full volume my ears were ringing!
The Not So Good (I really can't call it bad...)
While the speakers have excellent overall volume they are weak in the bass department. I really can't ding them too hard for this though. After all what did you expect from 4" stand alone speakers with no enclosure? Also my throat was getting sore from singing along by the time I got home. :-)
After about 130 miles of riding I can draw some preliminary conclusions.
- The speakers sound good with plenty of volume.
- If you are an audiophile you need to get a full fairing. (Or don't listen to music on a bike!)
- Easy to install! (1 to 2 hours and no trips to the emergency room!)
- The installed speakers don't detract from the bike's looks.
- Molly Hatchet's "Beatin the Odds" (or Uriah Heap's "Easy Living" or, or...) sounds awesome on a back road at 60 mph with the wind in your face!
Each speaker installs with 2 allen bolts, either chrome or black (included). The bolts go through mounting plates located on the back, outside (as installed) edge of the speakers. The bolts then go through small chrome stand offs (about 1/2" long) These bolts replace the 2 black bolts holding the 2 halves of the hand controls together on each side.
As I said this makes for a sturdy installation. I am however considering going back with some locktite just to make sure...
The answer is they can be tilted to whatever extent you are willing / capable of living with hand controls tilted to. I effect the speakers and hand controls become one unit with the speakers facing 180 out from the clutch / brake lever....
Hope that helps...
