Stage 1 or Not Stage 1
Old Mar 30, 2010 | 12:21 PM
bigshow97's Avatar
bigshow97
good info. yesterday i priced samson true dual cholos, heavy breather and race tuner. just need to pull the trigger. sounds like i should have priced labor also!!!
Old Mar 30, 2010 | 12:23 PM
FrozenInTime's Avatar
FrozenInTime
Question then doc (not being sarcastic). After I put on 2" slip-ons, my spark plugs were chalky-white and my eng was running very hot. No other mods at the time. It would not have hurt my eng? The stealership told me with it running that hot it would fry my eng from heat and void my warranty. I understand they want me to do it so they can get more $$, but an indy also told me the same.
Old Mar 30, 2010 | 12:25 PM
Slopneck's Avatar
Slopneck
If your plugs are white and chalky you need to take it in.
Old Mar 30, 2010 | 01:31 PM
FrozenInTime
I did. Cost me little north of $1100 for the SERT, Stage-1 cleaner, and dyno run. Counting the $200 for the slip-ons, ran about $130 per horse added. Yup, I (still) felt a little sore in the bum for that one. Saw me comming for sure. But, that extra 10 horses is nice. Now I can almost keep up with my buddys punched out (to 95) 88 rk.
Old Mar 30, 2010 | 08:56 PM
slowrollin's Avatar
slowrollin
Thanks everyone. You've helped me out a lot!!!!!
Old Mar 30, 2010 | 10:53 PM
oct1949's Avatar
oct1949
Originally Posted by slowrollin
I bought some Vance & Hines Slip-On mufflers for my 2010 Heritage. The dealer said that I should do a stage 1 and dyno. My question is, do I really need to do that just for switching to new mufflers? They say I'll see about another 6HP from that. Is a 6HP increase even noticeable?
Should get the 6hp just by changing the pipes...
I'd think U'd be lucky to get and other 6&6 out the stg1,, My dealer told me I'd get 10&10, before doing it... then after doing it, it ended up more like 6&6 or so, then they said oh.. thats normal.... chit the pipes alone is worth 5hp.
I really didn't even notice much difference in power after stg1, but it ran smoother and responded better..
When I did the cams was when I noticed a big difference,, the 96's stock cams are really holding them back....
Old Mar 31, 2010 | 03:32 AM
hpfatboy's Avatar
hpfatboy
Stage 1 for sure, let that bike BREATH a little bit!!!
Old Mar 31, 2010 | 12:46 PM
scannerman's Avatar
scannerman
I put v&h true duals with AN big sucker on my 06 deluxe, had my local shop install the pc3 and dyno---wow what a difference!
JHC210
Milwaukee Eight (M8)
25
Mar 18, 2019 08:02 PM
Redlegvzv
Sep 6, 2015 06:47 PM
St Glide
Mar 11, 2015 12:06 PM
Chris Creole
Oct 31, 2011 04:46 AM
Frankie-FLHXI
Mar 8, 2009 06:36 PM
