So the Leatherworks 312XL swingarm bag will comfortably hold 1 medium sized cat. I'm making a damn template for a mounting bracket, and she decides "oh look, i haven't been in here before. let me check it out for awhile. I'm not in your way, am i?"
Ha 2 funny. My (used to be the ol'ladys heh) toy poodle likes to jump on the bike seat while I mess with the bike. He needs one of those Harley mechanic shirts methinx.
Honestly, the Rustoleum Truck Bed Liner matches very nicely.. i, personally, screwed mine up pretty bad because I was impatient.. Only did 1 coat, let it dry for a day (it takes like 3), and reinstalled and went for a ride.. Did the brake pedal, shift linkage, shifter arm, several bolts (the brake pedal bolt, the bolts for the shift linkage, and even the acorn nut that holds the horn on).. the bolts all look fine, but everything else, where ever my boot hit it, kinda chipped off. Though the only real reason I even tried it was just to see how it looked. It looks good, therefore, I'm doing a more permanent solution and getting everything powdercoated, and others who have done it properly (3 coats or so, letting it properly dry each time) have had better results.
I've trying to do this from my iphone hope it works... It may be hard to see but you can see my brake peddle
Lone wolf..Just in case, iphone tip for ya. To get out of mobile mode for HD forums, on the very bottom hit normal version. Then u can access the insert url for links and images again. Also photobucket app allows you to upload pics from iPhone 'camera roll'.
Hey thx man, I need a iPhone for dumbys book sometimes
Ok let's give this a try
This is after 5 coats of krylon semi-flat and baking it after each coat, and also used spay tint on my tail light, I was going to change lights but kinda like how it turned out
