91 Fatboy not running
Old Jul 12, 2010 | 07:35 PM
fatty8235's Avatar
fatty8235
Stage I
Default 91 Fatboy not running
The bike shot flames and a big black cloud of smoke and hasn't ran since. I replaced the battery because the other one shorted out. Since then, I've check the circuit breaker on the back fender, the 3 relays under the dash, the ignition switch, coil and spark plugs. Plugs work in another ignition system, no power going to the coil. Starter turned initially but no longer turns over. Also, high beam light stopped working, low works fine. Does anyone have an idea as to what kind of damage I'm looking at?
Old Jul 12, 2010 | 09:46 PM
94fatboy's Avatar
94fatboy
I would start a thread in the EVO section...Less people but more specific knowledge and the bike
Old Jul 13, 2010 | 12:11 AM
Other Sheep's Avatar
Other Sheep
Did it shoot the flames at night time? That would have made a great video.
Sounds like you might have catastrophic damage. Engine work.
Old Jul 13, 2010 | 12:21 AM
panz4ever's Avatar
panz4ever
Part of me wants to know what happened just prior to your bike turning into a fire-breathing dragon. The other half says you fried your electrical system.........stator, voltage regulator, coil and wires, electronic ignition system, circuit breakers, basically your whole electrical system.
I would check and see if any wires are melted. Then I would test each component of the electrical system to see if anything is still functioning. not a difficult job, just time consuming.
79lowrider
Shovelhead
15
Apr 28, 2020 11:06 PM
btroy
Ironhead
Dec 19, 2008 08:45 AM
outfishin35
Aug 14, 2007 02:39 PM
meatball
Jun 28, 2006 11:50 PM
Alia1200
General Topics/Tech Tips
Jun 26, 2005 07:17 PM
