Engine noise
Old Sep 14, 2010 | 08:22 AM
remike's Avatar
remike
Smile
You have to put gas in that baby, petrol don't work.....
Old Sep 14, 2010 | 08:25 AM
Clayvis's Avatar
Clayvis
Try higher octane gas first. There is a great product here called Sentry. It is a fuel additive mostly used in the boating world. It takes the water out of the gas, plus boosts octane, cleans fuel injectors, and lubricates the top end. My locat $tealer sells it. My bike runs great with it.
I had your same problem. I new it wasn't pinging, as I am mapped quite rich, and the timing is right on. I changed the stock compensator sprocket to the Screaming Eagle upgrade. It cost about $250. Of course, I did it myself. Not sure what a shop would charge... The stock compensator bounces back and forth under hard accelartion causing the exact noise you describe. When all else fails, bite the bullet and get the heavy duty compensator that should have come from the factory! I'm glad I did. (or put louder pipes on-that cures all extraneous noise!)
Old Sep 14, 2010 | 11:08 AM
oldgeezer's Avatar
oldgeezer
I have 44,000 on my Standard and it has made the clicking sound for years. Mostly it happens within the first few miles of a ride and right before I shift to the next gear. I fixed mine with louder pipes.
Old Sep 14, 2010 | 01:57 PM
skulltrainharley's Avatar
skulltrainharley
grf4000 .... The kind of fuel i put in which is either Shell or BP is their quality stuff so they would have you believe who know's ? ....... anyway it works out to near as damn it Ł4.99 an imperial gallon and the cheaper supermarket stuff is about Ł4.48 an imperial gallon ..... Bottom line it's like everything here in this green and pleasant land called England we get screwed with everything we buy ....... definately dont live here by choice and to old to come over the pond .... that's where i should have been hatched
Old Sep 14, 2010 | 03:41 PM
Faast Ed's Avatar
Faast Ed
One small problem with that, my friend.
Pinging is not just a noise. It can be doing permanent harm to your motor by ignoring it. At the least, you should upgrade your fuel.
If yours happens to be compensator noise, disregard my comment above. LOL
Old Sep 14, 2010 | 04:49 PM
snook592's Avatar
snook592
Originally Posted by Milehigh
Hey Reddog8145,
My 2009 fatboy with 2200 miles sings the same song….like two coins being tapped together. I’ve only noticed it in the last few weeks. I switched to Amsoil at 1600 miles, but I’d be surprised if that has much to do with it.
From what I can tell it happens after the motor has warmed up and generally right after I up shift and accelerate. I ride my bike in the torque curve and the tapping seems to happen in the low to mid range. Cruising/steady throttle, or decelerating, I hear nothing but the symphony of the big v-twin. This bugs me quite a bit too, I'll need to figure this one out....
Why did you change the font so that a magnifying glass is needed to read your post???
Old Sep 14, 2010 | 06:05 PM
Faast Ed's Avatar
Faast Ed
Are you sayin' there were words typed in that box?
Old Sep 15, 2010 | 03:19 AM
reddog8145's Avatar
reddog8145
I spoke to the dealer again yesterday and threw the poor fuel issue into the discussion & suggested putting a higher octain fuel in . He told me that the new motors are designed to run on standard fuel with an octain of 92. Most fuel comes in at a rate of 95, but there are a number of companies that have been doing all sorts to the mix. He told me the name of a number of companies with dubious fuel, one of which happens to be one I use. I'm going to switch fuel stations and see if the continued lack of rattle continues. The dealer runs a trick Fat Bob and told me he found BP ultima to be a good product, its the same price as normal fuel and gives extra milage. I've heard this before but always been sceptical. Think I'l give this a try to and see if this makes any difference, I'l keep you posted.
Reddog GB
Old Sep 15, 2010 | 05:26 AM
Faast Ed's Avatar
Faast Ed
BP or Shell (when available) are the only fuels to see the inside of my fuel tank.
SportsterRider85
Aug 26, 2017 03:14 PM
tohi
Exhaust System Topics
Aug 8, 2012 08:38 PM
sioux565
Jul 19, 2011 07:57 PM
1peter
Jun 5, 2009 11:10 PM
hockey8787
Oct 6, 2008 07:19 AM
