Question about risers.
Old Sep 20, 2010 | 05:36 AM
BradD's Avatar
BradD
Default Question about risers.
Ok I have been reading these forums for a while now. It is part of my required morning reading while I am here in Kabul as a contractor. I bought a 99 Fatboy while I was home on vacation and love it. My question goes like this. The guy I bought it from put 2 inch pullback risers on it. The problem is now the bars feel loose so to say. Any time I park the bike and stand it back up the bars are warped to one side. It does it at slow speed turns to which as you can imagine gives an unsteady feeling. Is there any way to resolve this? Either store bought or do it yourself. thanks in advance for any help you guys can give.
Old Sep 20, 2010 | 07:59 AM
AusMongrel's Avatar
AusMongrel
It sounds to me that the risers are loose. Have you tried to tighten them?
Old Sep 20, 2010 | 08:24 AM
Kowan's Avatar
Kowan
The riser bushings are more than likely shot and need replaced.
Check to make sure the riser bolts aren't loose as AusMongrel suggested.
If the bolts aren't loose, the bushings are an easy replacement job.
Old Sep 21, 2010 | 12:04 AM
BradD's Avatar
BradD
Thanks. I took it to the dealer and they checked the bolts with a torque wrench and said they where good. They said that it might have something to do with the fact that it was rubber mounted? Make any sense to you guys? Thanks again for your help.
Old Sep 21, 2010 | 12:45 AM
Kowan's Avatar
Kowan
Yes, either rubber or Polyurethane bushings are used. They have some give but if it feels sloppy, they are more than likely shot and need replaced.
They are used to reduce handlebar vibration.
Old Sep 21, 2010 | 09:26 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Get Polyurethane riser bushings. It sounds like they have stock rubber bushings in them. With pullback risers you need poly!
Drew
Old Sep 22, 2010 | 12:55 AM
BradD's Avatar
BradD
Thanks for all the help guys. My dad is taking it to the dealer for service and a tire change so when I get home in November it will be ready to go. I will get him to get the bushings changed and poly ones put in. Thanks again for all the great advice.
Bonzai
Dec 10, 2013 08:08 PM
thoner7
Apr 30, 2013 07:16 AM
pheur
May 10, 2012 02:45 PM
evanstock
Apr 25, 2011 12:04 AM
niteowl02
Sep 7, 2008 10:24 PM
