Stage 1 alternatives?
Old Oct 15, 2010 | 04:55 PM
Murderface's Avatar
Murderface
Default Stage 1 alternatives?
I want more power! Then again, who doesnt. Nothing crazy, but i want new exhaust and a fuelpak, and of course a stage 1. Are there better intake upgrades out there? Is there any reason to buy from harley in this case? Iv heard their air filter is pretty lame. Whose got suggestions and where should i get them from?
Old Oct 16, 2010 | 03:33 AM
drknlo's Avatar
drknlo
I know i had to replace my stage 1 airfilter around 2k miles..the inside rubber seperated from the element. I took it back to the dealer and they told me they couldnt do anything about it. I went with a K&N.
Old Oct 16, 2010 | 06:48 AM
tk353's Avatar
tk353
Arlen Ness Big Sucker
Old Oct 16, 2010 | 07:47 AM
dv8's Avatar
dv8
That is bullshit, another reason I won't buy from a dealer unless I have no ther choice.
Old Oct 16, 2010 | 08:46 AM
Murderface's Avatar
Murderface
iv been reading a lot of bad things about that. so big sucker is a good way to go?
Old Oct 16, 2010 | 08:51 AM
jwilson77's Avatar
jwilson77
Same thing happened to mine; I too went with the K&N
Old Oct 16, 2010 | 01:12 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The big sucker is good. It comes with a K&N filter that is good "for a million miles." I run the Roland Sands Design Venturi Air cleaner which has a K&N filter as well. It is a little more expensive but is really nice looking. Whatever you need, let me know and I can get you a great deal. As far as tuners, the fuelpak is sufficient, but if you plan on changing anything more than air filter and exhaust ever, get a power commander or a TTS.
Drew
Old Oct 19, 2010 | 04:38 PM
James_Johnston's Avatar
James_Johnston
Former Sponsor
Drew
I could not have said it better myself, thank you.
Also, @Murderface, you can also go with the K&N Stage 1 and Stage 2:
If you are looking for a bit more power, you can go with one of the K&N RK-kits. The RK-3909 added 7 HP @ 5K RPM at the wheel, and the RK-3910 added 12.05 HP @ 5k RPM at the wheel; BUT the RK-3930 sticks out a lot more under the stock cover. The RK kits cost more, but they will add a very noticeable difference, even without pipes and a tuner/rejet.
You can also go with one of the Airchargers, 63-1125P
or 63-1125. Both added 10.21 HP @ 4953 RPM at the wheel and they have the Heavy Breather look.
Sethc1020
May 13, 2019 08:12 AM
018245
Nov 2, 2013 11:56 PM
cramil
Jan 27, 2010 07:02 AM
Douce48
May 1, 2007 05:19 PM
docpage
Exhaust System Topics
Aug 22, 2006 09:21 AM
