no remap after pipe and A/C change
My map also cost $150 so I would recommend holding off and putting that money toward some type of fuel management system. JMHO
I am always suspcious when I want to buy something and suddenly the bill jumps $500 or whatever, but it is a fact that the bikes already run extremely lean from the factory. That means that the mixture or air and gasoline is set to meet the EPA's standards for air quality in this country. It may seem like it is running fine, but once you add a tuner and get it properly tuned you will realize it was running like crap.
The person who explained this the best to me was Geoff Gaites from The Cycle Doctor in Costa Mesa, CA where I got my bike Dynoed last time. Call him and talk to him. As far as the "compensation" by the computer, not so much in my opinion. He can also explain this far better than I can. 949-645-1235
Honestly, I spent a lot of money on my bike and another few hundred on this and that to make it run as it should run is well worth it to me. The compensation by the computer is not going to change enough and the factory download is junk. Spend a little more and get a tuner and you will feel the difference. I had the download on my bike when I bought it used. It ran like crap. Changed the already aftermarket pipes and it ran even worse. Added a power commander and it felt like a new bike. Just my experience.
Then I took for a Dyno at a "cheap" Dyno place. It ran much bettter than before. Then I built the motor and went for a real Dyno. The difference was night and day. Really. I have not once felt like I wasted the money on the Dyno tune.
Drew
And if you should decide later down the road to go with cams/headwork/etc., that's one cost you don't have to figure into the build.
Same folks will tell you the bike will run better and have more hp with a fuel manager or remap. I may get one down the road but for now I see no compelling need.
Drew
With that said, I did notice a big difference when I finally got a PCIII and had my bike dyno tuned. So, that's why I suggest to the OP to SPEND the extra $$$ and get some type of fuel management system and avoid the re map. Some dealers will tell you a re map works and others will say it does nothing.
