hypothetical question
Old Dec 11, 2010 | 07:00 PM
PowerSmoke's Avatar
PowerSmoke
Default hypothetical question
I have an opportunity to buy a complete motor/tranny/primary out of another bike at a really good price--complete S&S motor/open primary/6 spd tranny.
Will this setup fit in a stck softail frame? is there an adaptor or something needed to get the Evo style S&S to fit?
Thanks
Old Dec 11, 2010 | 07:02 PM
TORQUEY's Avatar
TORQUEY
It depends. Contact S&S for starts and ask if this combo will work in your bike. Contact HD as well. Many or most of these set ups are for right side drive, so prepare for mods. On the other hand, S & S has found its way onto many a HD.
Old Dec 11, 2010 | 07:07 PM
PowerSmoke's Avatar
PowerSmoke
this set up is a left side drive with a belt--I checked that first..
Old Dec 11, 2010 | 11:54 PM
MCSarge's Avatar
MCSarge
You need to provide a little more information on the motor and tranny. Are they bolted together with a swing arm mount at the back of the trans, or are they separate and held together by the primary? If the motor and trans bolt together than you"ll need a bagger frame to support the swing arm, if they are separate and held together with the primary you can use a softail or hard tail frame. Good luck on your project.
Old Dec 12, 2010 | 12:12 AM
kk6pg's Avatar
kk6pg
Hypothetical Answer:
Nothing is impossible. Be creative
Old Dec 12, 2010 | 10:58 AM
PowerSmoke's Avatar
PowerSmoke
unfortunately--I can only be as creative as my wallet will allow, and right now that aint much.
Hoping this is a fairly easy bolt-on, with maybe an adaptor or something.
Old Dec 12, 2010 | 11:01 AM
PowerSmoke's Avatar
PowerSmoke
It is an S&S motor,with a Bruto V primary, connecting a Jims 6 spd.
Left side belt drive.
Its in a hardtail built by Rick Fairless in Dallas.
Mild frame--nothing crazy.
I would be putting in stock 2006 Softail frame.
Old Dec 12, 2010 | 11:45 AM
MCSarge's Avatar
MCSarge
Sounds like a fun project. There is so much stuff out there for Softails that you should be able to put something together for a reasonable amount of money. I do a lot of shopping on line and search a lot of ebay listings. I have found lots of parts on ebay for a third or less of retail, just be sure you know what you need. Post up pics as you start building, and don't be shy about asking for help before you spend the money.
Old Dec 12, 2010 | 01:17 PM
PowerSmoke's Avatar
PowerSmoke
my builder just called me to say this will not work...
Something about the way everything mounts in a "balanced" motor frame.
Said it would be no problem on an earlier model, but the swingarm is connected to the tranny or something, and the one I was looking at is not made for that..
oh well--thanks for the help!
Old Dec 12, 2010 | 01:34 PM
MCSarge's Avatar
MCSarge
You have a bagger motor and trans. The motor and trans are bolted together and the swing arm mounts to the back of the transmission. Might be able to mount it in an aftermarket FXR or dyna frame. Unusual setup to come out of a hard tail frame.
20"ape
Oct 17, 2014 01:43 PM
daxcobra
Custom Models
Apr 12, 2014 06:51 AM
semiller1911
Mar 28, 2013 10:46 AM
PowerSmoke
Exhaust System Topics
Dec 14, 2010 05:34 PM
rawldog
Jan 22, 2010 03:34 PM
