Help polishing forks
Old Jan 11, 2011 | 08:10 PM
KumaRide's Avatar
KumaRide
lo-ride left some nice, detailed info but reading that was more exhausting then running to the garage to touch up and polish the forks.
You do not need to polish once a month. Maybe once every three, six or ? Whatever floats your boat. And polishing takes a few minutes.
I also removed tire and fender.
Old Jan 11, 2011 | 08:14 PM
lo-rider's Avatar
lo-rider
Default clarification
Originally Posted by JIMSFBL
...what kind of clear coat and how is it applied?
...I'm now thinking of doing this... but I don't want to have to sand and polish them once a month.
1st, I am not recommending clear-coat, only stating that some do that.
There is no need to sand & polish every month. Sanding would only be done to minimize the stone-dings or scratches which may accumulate. And polishing can be done as infrequently as you'd like, perhaps once or twice a year.
Old Jan 11, 2011 | 09:33 PM
JIMSFBL's Avatar
JIMSFBL
Ok that is what I was trying to ask. The sanding and redo. Anyway, thanks for clarifying. I'm going to do this to the lowers on my Ultra and didn't know the lessens I would go through on the up keep.
I thought your post was good info thanks!
Old Jan 20, 2011 | 04:25 AM
05Hog's Avatar
05Hog
Originally Posted by coronerrpm
Very interesting but what is the upkeep? Do you need a clear of some type put on? I have a scratch on mine from removing a reflector
When I did mine I used fishing line to "saw" through the backing on the reflector. This eliminates those scratches. Remove rest of adhesive with goof off , WD-40 or whatever your preference is.
Old Jan 20, 2011 | 12:59 PM
blackhog5150's Avatar
blackhog5150
Using a cloth spirial sewn buffing wheel and an electric drill, apply white rouge (usually in stick form) to the spirial sewn buffing wheel in your drill by holding the end against the spinning wheel in the drill. Use light pressure as you polish the tubes, re-apply more white rouge as needed. Follow up with a clean soft buffing wheel. This will produce the best result possible.
rbferg
Feb 18, 2014 07:22 PM
Stevenacnj
Mar 31, 2009 09:32 AM
Devildragon
Aug 13, 2008 11:31 AM
Hardly Dangerous
Jan 5, 2008 11:10 AM
58nluvnit
Nov 17, 2007 01:00 PM
