Best Cam for a Stage I...........
Old Feb 25, 2011 | 06:20 AM
  #31
Notgrownup's Avatar
Notgrownup
Originally Posted by Rocker_UAE
Guys lemme throw in a quick question what would be the best tuner and cam to go with if ur planning to intall the 103" big bore kit??? The most common i read on ppls sigs is the SE255s ??
From what i read and hear the Power Commander with auto tune is the way to go...
Old Feb 25, 2011 | 12:10 PM
  #32
dpayne7571's Avatar
dpayne7571
I'm going with the 255's. One harley dealer told me they could use my PCIII and the other dealer told me I had to get the SERT, that they don't use the PCIII, so I'm going with the other dealer to save the extra 480.00!!
Old Feb 25, 2011 | 12:36 PM
  #33
jlasoftail's Avatar
jlasoftail
I'm sure you'll be happy with the 255's. I do have this question for you guys though: at what point are the cams to aggressive, and start doing damage to your engine. For those of us that want to be able to rack up the miles, you have to think about drivability, and not just dyno numbers...
Old Feb 25, 2011 | 12:56 PM
  #34
Notgrownup's Avatar
Notgrownup
This was my quandry and with the 26H i feel the bike is not pushed to hard, it actually seems to run smoother than before...Much quieter than before and i think this is because of the pushrods though...255's seem to be a good all around cam...if low end tq and 2 up riding and not too aggressive i think the
255's, 26H, S&S 510, TW6-6 are all good bolt in cams from what i read anyway...
Old Feb 25, 2011 | 01:33 PM
  #35
Chaddy-P's Avatar
Chaddy-P
Default Woods
Just did a Woods TW-555 install on my 07 standard and couldn't be happier. went from 76hp to 90hp.
Old Feb 25, 2011 | 04:19 PM
  #36
lionsqrne's Avatar
lionsqrne
Same here.
But I know I read somewhere once that you shouldn't go with a cam with more than .500 lift on a stock 96 otherwise it got to aggressive. I just cannot remember where I read it.
Mine didn't really get quieter with the 26h but then I also put on a D&D Fatcat. It has more a throaty growl to it now which I like. Smoother for sure.
Old Feb 25, 2011 | 04:31 PM
  #37
Notgrownup's Avatar
Notgrownup
Originally Posted by lionsqrne
Same here.
Qieter ( valve train) i should have specified.
Old Feb 26, 2011 | 10:35 AM
  #38
oct1949's Avatar
oct1949
If U look in the Sticky threads at the top of the touring and Softail sections U'll find both of them have threads on DYNO Sheets...With hundreds of dyno sheets to look at on different cams and builds
For a bolt in cam its mostly about the Intake closing timing event that makes them have the TQ where U want it....Between 25-35* ABDC, I-C will give U good Low-Mid TQ..
There are a lots of cams that have 30-36 I-C and will give U a good Low-Mid and theres not really much difference between them.
Son and I have ran SE204's, Andrews 26h's, and the newer S&S 551's. all with SERT and dyno tuned since 07 in our other wise stock 96's..
The four bikes we've done cams in all made between 91-95#'sTQ and 79-81 HP... Those were all SAE tunes..
The one we like best for low-mid TQ is the S&S 551, and they will hang in a little longer than the SE255's with as much low-mid end TQ. Plus U can get the EZ start ones if U want to. link below on them
http://www.sscycle.com/feature/featureview.php?s_id=10
The SE204's are are great cam with a really great Lope, but needs a 4* advance gear to move the line to the left for better low power.
I like the 26h's I have but they were 2-3# of TQ lower, but I still have the stock headers and slip ons. A good 2-1 system should easy make 95/low80's
I am happy with them for our mostly two up riding and have a Great Tq line for low-mid TQ on our Heritage..
If I do another cam for low-mid power, I'll look at the S&S 551 real hard.
Heres a link that shows my stock sheet VS stg1 and cams sheet.. its more than just a 5-10% increase. more like 15% under 2500,, 20% at 4k,, and almost 30% at 5200..
Its the first post in the thread if U want to look at them.
https://www.hdforums.com/forum/softa...-softails.html
Notice that the TQ line never goes below 80. under 5200 rpm, thats more than the max she made in stock form.
The sheets will show what U really get..
U'll end up getting a totally different TQ line, better fuel mileage, cooler running motor and will be able to use 6th gear easy even at 60mph, and not need to down shift nearly as often for normal passing
If U want to see how the cams compare, heres the best site I've found to help U look at all the cam specs..
Most of the top cams are in here with there timing events.. lets U compare three cams to others at the same time
http://www.bigboyzcycles.com/tccams.htm
Old Feb 26, 2011 | 10:45 AM
  #39
dpayne7571's Avatar
dpayne7571
The four bikes we've done cams in all made between 91-95#'sTQ and 79-81 HP... Those were all SAE 4th gear tunes..
Great follow up. I was already set on ordering the 255's, but I'm going to do some research now on the S&S 551. I would love to have the sound of the se204, but just not enough low end torque unfortunately for me as I'm usually shifting before 4k.
Old Feb 26, 2011 | 10:54 AM
  #40
oct1949's Avatar
oct1949
Son had the 204's in his 07 Deuce and 09 Night train.. He bout 180 and on those ligher bikes and with the 4* advance they pull good in the lower rpms..
He now has 10 Street Glide with the 551's and loves them. there stump pullers and as I said they hang in really good when U wind her out also. Don't have a copy of His sheet or I'd put it in for ya.. but S&S shows it on there site.
He didn't get 100#'s TQ but ended up with 95.. he did the new V&H's 2-1-2 with Rush slip-ons on this one.
