First Service
Old Feb 27, 2011 | 02:59 PM
Crossbonesgirl's Avatar
Crossbonesgirl
Default First Service
My 09 Crossbones has 660 miles on it now. I found her as a demo model and had only 200 to start. Got a great deal.. Is it true I should have my first service at 800 miles or is it okay to wait until 1000?
Thanks,
Crossbonesgirl
Old Feb 27, 2011 | 03:21 PM
Santo's Avatar
Santo
I did mine at 1k. There really isnt much that they do to it, get yourself an shop manual and try it yourself. Save some cash..
Old Feb 27, 2011 | 03:32 PM
watchluvr4ever's Avatar
watchluvr4ever
Is the Crossbones first service at a different interval than other Softails? The first service for a Fat Boy is at 2000 miles.
Old Feb 27, 2011 | 03:34 PM
cpiad's Avatar
cpiad
Account Closed
They dont do anything and charge you almost $300 and you run risk of least experienced guy will fuxx ur bike up. Buy Redline lubes and K&N oil filter and do it yourself. Harley oil made by SUNOCO...steer clear of it. Buy Redline V twin lube. If you live in hot summer place get 20w60 otherwise 20w50 will do. SummitRacing has it all in one place. Then you can go 5000 until next engine oil and primary chain case oil. Tyranny oil can go to 20000 but I do it 15000.
Buy a shop manual and figure out how to CHECK clutch play and other items noted in users and shop manual under normal maintenance..I just did it all and it came out to about $80 using all synthetics and premium K&N oil filter. You will learn about your bike and you will know who did what....
poppavein's Avatar
poppavein
My 2011 softail owner's manual says that springers are a special case and their first service is at 500 miles and another at 1000. And ongoing maintenance is at 2500 miles vs. 5000 miles for other softails. Looks like the springer front end takes a bit more maintenance.
If they had changed the oil and checked the front end at 200 miles then I would wait until 1000. Otherwise I would do it now.
I just got a new Blackline and will be changing oil in the first 100 or 200. I'll do normal oil changes after that.
Old Feb 27, 2011 | 03:37 PM
watchluvr4ever
Sorry I misspoke normal first service for a Fat Boy is at 1000 miles.
Old Feb 27, 2011 | 04:24 PM
Crossbonesgirl
Default Great Advice on First Service
Thanks for the great advice on the first service. I will get that manual and make sure things are getting done right. Great advice on the type of oil and filters to use too.
Ride Fast, Ride Safe
Crossbonesgirl
Old Feb 27, 2011 | 05:19 PM
lp johnny's Avatar
lp johnny
[quote=poppavein;7977828]My 2011 softail owner's manual says that springers are a special case and their first service is at 500 miles and another at 1000. And ongoing maintenance is at 2500 miles vs. 5000 miles for other softails. Looks like the springer front end takes a bit more maintenance.
my 2010 manual says the same
Old Feb 27, 2011 | 11:06 PM
oct1949's Avatar
oct1949
ur worried about 200 miles,,,, just take in when U can get the app....
Old Feb 27, 2011 | 11:26 PM
Rakthi's Avatar
Rakthi
You're supposed to go in at 500 miles for the adjustment/check up of the rockers. You also have to go in every 2500 miles for checking the rockers and getting the steering head filled with some fresh grease.
DO NOT attempt to muck about with the rockers if you don't know what you are doing. You have to disconnect the rockers from the fork which is highly dangerous if not done correctly. Check the service manual!
You can fill the steering head with grease yourself.
Personally, I pump some grease in the steering head and check the torque on the rockers every 2,500 (without disconnecting anything). got about 10,000 miles now and everything still in spec.
