Searched the forums and can't find anyone running this Avon tire on the FRONT of their FB:
150/80R-17 (72V) Avon Cobra AV71 Front Motorcycle Tire
I am trying to figure out if the Avon 150mm will fit on the front end or not. It appears to be about 1.2" larger diameter and .14" wider than the Dunlop 408f.
talking about running the "same size" Metzler with no issues. According to the specs the Metzler is slightly larger diameter 26.73 vs. 26.5 and slightly wider 5.98 vs 5.9 but didn't want to trust published specs over actual experience.
I am planning on running this on the rear: 200/55VR-17 (78V) Avon Cobra AV72 Rear Motorcycle Tire
Thanks for any help / feedback!
Reason: clarification
