speedo quits
Old Mar 27, 2011 | 01:42 PM
Smokey Burnouts's Avatar
Smokey Burnouts
Default speedo quits
This has happened twice now.... if i really jam through the gears(1-4) I will notice that it no longer shows my speed, 6th gear light and will run kinda rough even has shut off when coming up to a stop. Shut bike off using ignition switch, wait a few seconds and all is well!!
Any ideas? any reason for major concern?
thanks
Old Mar 27, 2011 | 01:53 PM
hspring03's Avatar
hspring03
Sounds like the speed sensor on top of the transmission..
Clean it off, plug it back and check.. Replace the sensor if it keeps doing it
Old Mar 27, 2011 | 02:04 PM
Smokey Burnouts
OK... thanks for the advice, i will give that a look!
Old Mar 27, 2011 | 02:11 PM
xwhyz1959's Avatar
xwhyz1959
My 06 Sporty did the same thing. As long as I was riding easy, no problem. As soon as I got on the throttle hard, the speedo would drop out. Turn off ignition, turn back on, all is well. What I found was a wire under my gas tank that had been rubbing against my idle/throttle cables, which happen to be braided. As soon as I would get on the throttle it would shift the position of the cables and make contact with the exposed wires causing a ground fault I suppose you could call it.
jcboof
Jun 29, 2020 01:41 PM
Texas_Rider11B
Electrical/Lighting/Alarm
Jan 16, 2015 10:55 PM
mswing1234
Sep 18, 2014 06:02 PM
joker joe
Jul 25, 2014 12:04 PM
bigirn
Jul 31, 2011 07:01 PM
