Forward Controls on a FXSTC !!!
Old Mar 31, 2011 | 04:40 PM
KENNSKE's Avatar
KENNSKE
5th Gear
Question Forward Controls on a FXSTC !!!
I was just wondering if any of yall have used the Arlen Ness 3" forward control bracket kit? It's the one that lets you keep all your stock pegs, ect. If so, what did you think of them? Any problem? etc!!!
Old Mar 31, 2011 | 06:04 PM
Hot Rod King's Avatar
Hot Rod King
I know its not the same bike but I have them on my Deuce and I love 'em. Perfect fit and finish, you wont be sorry
Old Mar 31, 2011 | 06:07 PM
KENNSKE's Avatar
KENNSKE
5th Gear
Thanks, thats what I was hoping to hear.
Old Mar 31, 2011 | 06:08 PM
TheNameIs"B"'s Avatar
TheNameIs"B"
Go for it, great kit. I just installed mine a couple weeks ago and they are great and easy to install. I bought a $7 bleeder kit that made the job really clean. If you don't have a lift the Harbor Freight one will work fine for only $89.
Old Mar 31, 2011 | 06:11 PM
RANGER73's Avatar
RANGER73
Ya, I used them. No problem here. Saved a ton of money this way. Nice and solid, quality chrome. The only problem I had (and not with the kit) was my shift peg was red locktighted on, so I had to snap the bolt. I had a replacement because I was going to replace it anyway. Oh, ya, you'll need a bike jack or a way to tie her off, because you'll be removing the jiffy stand for a relo to the extension arm, and the bike has to stand upright. Just a thought. Have fun, is was an easy install. Mine's a 94 FXSTC.
Old Mar 31, 2011 | 08:55 PM
KENNSKE's Avatar
KENNSKE
5th Gear
FYI, Here are the controls im going to get. The seller said that this kit contains everything that is needed to move my stock parts 3" forward!!! (Is he right?)
http://cgi.ebay.com/ebaymotors/2007-...Q5fAccessories
Old Mar 31, 2011 | 09:01 PM
stef's Avatar
stef
Put this kit on my '07 FXSTC just after buying new, best purchase/mod I've made.
Old Mar 31, 2011 | 09:03 PM
TheNameIs"B"
Yep, everything is in that kit(Same one I bought) Now get yourself a lift, a drain tube for breakfluid, and a pack of black zip ties. Tip: use a heat gun before trying to break the Torx bolts loose and use high quality torx sockets!
Old Mar 31, 2011 | 09:06 PM
RICHIEMACK's Avatar
RICHIEMACK
Every thing is there but the shift rod is kind of cheezy.i got a ajustiable one on ebay for $30 i see the a ness kit for $117 ebay ,the brake line alone is $75
Old Mar 31, 2011 | 09:09 PM
RICHIEMACK's Avatar
RICHIEMACK
Originally Posted by thenameis"b"
yep, everything is in that kit(same one i bought) now get yourself a lift, a drain tube for breakfluid, and a pack of black zip ties. Tip: Use a heat gun before trying to break the torx bolts loose and use high quality torx sockets!
b ,,where did youn get the bleeder kit,i still have to do mine
