Painting over chrome
Old Apr 12, 2011 | 08:53 AM
frank1's Avatar
frank1
Default Painting over chrome
has anyone painted over chrome. what did you use and how were the results. i have a chrome crash bar that i want to install on a crossbones. thanks
Old Apr 12, 2011 | 08:57 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Get it powdercoated. More durable than paint.
Old Apr 12, 2011 | 09:01 AM
ord sgt's Avatar
ord sgt
I painted the horn cover and battery band with flat black wrinkle finish paint. After removing the parts from the bike, I scuffed the original finish with a scothbrite nylon pad, then sprayed with 2 coats of paint, then re-installed.
The paint has lasted for 3 years now and no sign of flaking or chipping.
Old Apr 12, 2011 | 09:02 AM
Gman in NC's Avatar
Gman in NC
Check on Dupli Color's new see through colors. I know they have them in 'black chrme'. It has a prep spray that goes on first. Guys are painting car wheels with this stuff.
Old Apr 12, 2011 | 10:03 AM
twofish's Avatar
twofish
Nothing wrong with powder coating for sure.
http://s1125.photobucket.com/albums/...=BEST-copy.jpg
I’ve rough up some chrome items, cleaned with alcohol,
rattled canned primer, and the sprayed the black.
No problems with any of them.
Try it, what do you have to loose?
Old Apr 12, 2011 | 02:04 PM
spiker77's Avatar
spiker77
6th Gear
painted lots of chrome bike parts and never had any trouble.i used 220 grit sand paper and then sprayed with a high build primer then painted and cleared
Old Apr 12, 2011 | 11:05 PM
frank1's Avatar
frank1
Thanks for the help/info
Old Apr 12, 2011 | 11:49 PM
NoRegerts's Avatar
NoRegerts
What these guys have said, sand and prime. But use an etching primer. It's designed to be sprayed onto bare metal. It has an acid that will better adhere to the surface. Powder coat is pretty cheap though, in case you hadn't considered it.
Old Apr 13, 2011 | 07:42 AM
brettnbama's Avatar
brettnbama
On something like an engine guard that has a high probablility of getting hit by stuff (rocks, your feet, the ground) I would go with powdercoat over paint.
Old Apr 14, 2011 | 09:30 AM
vulcanater's Avatar
vulcanater
I've painted lots of chrome parts with no problems at all. They have held up great and I live down a mile of gravel road. Like stated above, I sanded the parts and then used a self etching primer from a rattle can and the painted and clear coated from rattle cans too. Its way cheaper than powder coating. And if you ever do get a chip in it, just touch it up.
