Deuce Rear Pulley Bolts
Old Apr 13, 2011 | 12:31 PM
Hutchdown's Avatar
Hutchdown
6th Gear
Default Deuce Rear Pulley Bolts
I was hoping to get some advice from the community. I recently bought an 01 Deuce. Before I started the riding season, I wanted a tech to do a once over, so I took it to my local HD dealer and had them do a 15k check on it.
Most of the things they found were small fixes and nit noid crap, but the big thing they noticed was that the rear pulley bolts and come loose and tore up the threads in the rear wheel hub. The service manager said he had seen this before on the Deuce and said he would send the rim off to a machine shop where they would drill out the holes and rethread with new helicoils.
After about a week of downtime I got my bike back on Saturday and commenced to do some riding, (it was 75 here in Indiana and beautiful) Everything was going great until about an hour into my ride when I heard a god awful noise coming from the back wheel. I looked down and saw the pulley flapping back and forth shortly before the wheel finally locked up when I came to a full stop.
All 5 pulley bolts had backed completely out. A fellow rider saw me stranded on the side of the road and helped me tighten them back down and I limped back home.
The dealer opened back up on Tuesday morning and I told him what happened and he promised to get to the bottom of it. After talking to him today, his response was, "we tightened it back up, put a bunch of red loctite on it and it should be good to go"
I asked him if they were loctited the first time and he assured me they were, so in effect he did nothing new this time and is claiming it is fixed. My question to you is, what could have caused these to back out if they were properly torqued and loctited the first time? And should I be satisfied with this "fix" of just adding extra loctite? Also, if someone has a theory why all 5 bolts could have backed out one hour after getting the bike back from the shop, I would be happy to relay it to my service tech.
Thanks in advance,
Hutch
Old Apr 13, 2011 | 02:00 PM
Tx_Outlaw's Avatar
Tx_Outlaw
Sounds like someone did'nt put loctite (or correct loctite) on the bolts the first time.... Also when using red loctite, it's best to let the part set for 24 hours to cure correctly before use.
Another theory...... the machine shop uses oil when drilling and threading holes. Maybe it didn't get cleaned properly.
Old Apr 13, 2011 | 02:17 PM
2black1s's Avatar
2black1s
If that pulley loosened up in an hour of riding the most probable cause is that they were never properly tightened (in my opinion).
My Duece has had the pulley off-and-on at every tire change, bolts have never been replaced - still using originals, have never seen a torque wrench, have never been loctited... And they've never come loose!
They simply did not tighten them.
Old Apr 14, 2011 | 07:53 AM
Hutchdown's Avatar
Hutchdown
6th Gear
The service manager was adamant that they torqued the bolts to spec with red loctite, assuming he isn't mistaken is their any other explanation as to why those bolts all backed out?
Old Apr 14, 2011 | 08:42 AM
Tx_Outlaw's Avatar
Tx_Outlaw
I would refer back to my oil in the threads then.....
Old Apr 14, 2011 | 09:26 AM
stevevfd's Avatar
stevevfd
I was always told that the bolts in the pulley are one time use. Torque them down, and if they ever have to come out, they need to be replaced. It's something with torquing them then loosening them that weakens them. You may be ok, but I'd throw a fit until they replaced the bolts, locktited them, and torqued them properly.
Old Apr 14, 2011 | 11:57 AM
PanHeadRich's Avatar
PanHeadRich
Hmmm, for them to literally come loose an hour into your ride tells me that they were probably only finger tight and not torqued or loctited at all.
I just changed my rear rotor & pulley and had a terrible time busting the Torx bolts loose. The factory didn't use loctite on mine, but due to the corrosion from using dis-similar metals, I needed a pneumatic impact wrench to bust them loose.
Because of the corrosion I actually used an anti-seize compound on the treads when reinstalled. I'm not sure if that was a good idea or not, but I'll just keep an eye on those torx bolts to see if they're staying snug. I just didn't want the corrosion coming back. I was amazed that I didn't strip the hubs threads getting the bolts out. My risers did strip like that.
Personally I think you're alright now, just keep an eye on them. Check them before every ride for a little while.
Old Apr 14, 2011 | 12:02 PM
PanHeadRich
I highly doubt that this is true. If the FAA allows the bolts that hold a propeller on a plane to be reused, there's no reason hub bolts couldn't be reused for pulleys & rotors.
Just my 2 cents
Old Apr 14, 2011 | 04:54 PM
Tom84FXST's Avatar
Tom84FXST
Loctite or no... oil or no...if they were properly tightened, no way they would come loose in an hour...ether they did not tighten them, or the machine shop screwed up the heli-coil job.
Old Apr 14, 2011 | 06:16 PM
JAKE 2544's Avatar
JAKE 2544
I agree with tom,they were never tightened.
baxter
Aug 12, 2021 08:25 AM
JayLo
Aug 11, 2021 05:22 PM
schwabizzle
Oct 8, 2011 05:45 AM
anubisss
Jul 19, 2011 04:28 PM
Prodriverdon
May 9, 2008 11:05 AM
