Need help with fork slider dust cap ID
Old May 1, 2011 | 12:14 AM
bill in okc's Avatar
bill in okc
Default Need help with fork slider dust cap ID
I have two 41mm sliders that use different dust caps/boots. They are identical except at the top where the boot fits. Both are Showa p/n G593-30 with the bottom one being SA-1 and the top one from my 08 FXSTB being SA-3. I am trying to figure out which rubber boot I need for the SA-1 fork. I think the SA-1 might be from a 2007 FXSTC. It might be HD p/n 48620-07. Does anyone know what bikes this fork slider came oem and does a black rubber boot exist for it?
Thanks,
Bill
Old Jun 2, 2011 | 09:38 AM
mobsters1972's Avatar
mobsters1972
Default Heelp
I have the same problem, need your help. I sent you a PM.
Old Jun 2, 2011 | 09:39 AM
mobsters1972
Default Part Number
Does anybody know what the dust seal part # is for the fork slider pictured at the bottom. I have the same problem and i need help.
Old Jun 8, 2011 | 09:38 PM
hwyman's Avatar
hwyman
6th Gear
Just curious if you found your answer i have the same problem..
Old Jun 8, 2011 | 10:03 PM
bill in okc
I *think* it might be this but I never tried it. The set screws look like a match for the way the tops are machined. It supposedly was used on several years FXSTC and FXWG. The parts book shows a second inner seal that the parts guy told me is not used with the standard FXSTB forks, so I'm guessing it is for the FXSTC? Can anyone confirm?
Old Jun 9, 2011 | 05:22 PM
hwyman's Avatar
hwyman
6th Gear
yes i can confirm that those are just decorative caps you still need the rubber dust covers/wipers..for underneath those...
Old Jun 9, 2011 | 05:23 PM
hwyman's Avatar
hwyman
6th Gear
and yes sorry those are for the fxstc...
Old Aug 24, 2011 | 08:57 PM
mars636's Avatar
mars636
what caps did you go with? I have the same problem, i have a 07 night train and bought sliders from a 07 fxstc. mine are like the ones on top and the new ones are like the ones on the bottom. Is everything the same with the forks except where the dust cap goes on? If i buy just the caps of a FXSTC will they swap over to my bike?
Old Aug 25, 2011 | 12:28 AM
Scheers44's Avatar
Scheers44
If you got FXSTC sliders get the stock caps and pc em black it'll look better that way anyways.. the rubber boots fade and look like chit after some time anyways...
Chrishlad
Jul 2, 2017 09:31 AM
johnsonzx14
Mar 5, 2014 10:50 AM
panic_fan
Jan 18, 2011 02:21 PM
rickb
Apr 7, 2010 07:31 PM
Miklnparker
Apr 30, 2007 12:56 AM
