Installing handle bars... how hard can it be?
1. How hard could it be?
2. Is it worth doing yourself for the $200+ savings you get with the bar kits that cost around $500?
Drew
if you have your manual you will be fine i wouldnt do the job without one ..
Drew
. I'm a die hard DIYer so saving money wasn't my primary motivation for doing the job myself.
Tools needed:
-Snap ring pliers (large ones for the ring in the transmission cover and small ones, or a flathead screwdriver for the snap ring holding on the clutch cable)
-Standard wrench set (open and closed end, the whole set up to, I believe, 3/4")
-Allen wrenches (a pretty large one for the transmission fill plug and smaller ones for various other parts. I had a set that used a 3/8" drive so I could use my socket wrench)
-Standard set of sockets
-Torx set (I used ones that had a 3/8 drive so I could use my socket wrench)
-The trusty old crescent wrench (just for convenience)
I believe this is all. Like everyone else said, its not a hard job. I did it by myself this weekend. There are just some frustrating things at times (I fought the damned throttle cable while trying to get it out of the housing for almost 30 minutes!) but for the most part, everything is simple if you take it step by step.
THE MANUAL IS YOUR FRIEND! You'll have to do some flipping back and forth between pages but everything is basically spelled out for you.
If you need any help, hit me up or any of the other guys on here who has done it. Good Luck!
