Carb
Old May 15, 2011 | 09:53 AM
Doug S's Avatar
Doug S
If your running your bike around the street at 5 grand+, you might feel a difference-(see the chart attached)-@6500rpms the Mikumi yields 2.5HP more...yippee.
An engine is an air machine, if both types of carbs are properly tuned then the only difference in power will be from the 2mm bigger bore of the Mikuni. Some say the Mikuni has better throttle responce, maybe it does but I never noticed a big difference. Poor throttle responce can be caused by a number of things, for example a too fat highspeed circuit will cause an engine to bog down under high throttle settings, no matter what carb you use.
I'm not knocking the Mik or S&S, I just don't see a compelling reason to throw money at them unless your CV is totally screwed up. You would be better served putting that 300 bucks into a new cam(s) and then doing a proper CV rejet, that would put some actual horses at the rear tire.
D
Old May 15, 2011 | 11:01 AM
Northside's Avatar
Northside
The CV is a great carb. Properly tuned it's hard to beat. A Mikuni HSR is a fantastic carb. Miks are way more adjustable than the CV, but do you need that on a stock Twin Cam? You won't gain much between the two, if both are set up right, until you start modding the engine. Then the Mikuni is "the only way to go."
Old May 15, 2011 | 01:01 PM
story808's Avatar
story808
I'm not tryig to start anything Doug and I see your point but I did notice a huge difference in performance and trottle response... may because its a flat-slide carb? I just know I'm really happy with running the Mikuni and through my experience it made a world of difference.
Old May 15, 2011 | 02:35 PM
roadkingharry's Avatar
roadkingharry
D
Back in the day I had a '73 Triumph Bonneville 750 with a stock carb. I had a Mikuni put on and noticed an immediate improvement in acceleration, way better than stock. Mikuni has an excellent history and reputation. That being said, seeing the numbers on that dyno sheet, I'll stick with my cv and keep making adjustments until I get mine right. The thing that concerns me though is taking the steel breather bolts in and out of the aluminum heads.Seems like there's always a little material coming out with the bolts.
Old May 15, 2011 | 03:03 PM
NickD's Avatar
NickD
The Mikuni HSR 42 or 45 (depending on HP) are the best carbs out there, IMHO. S&S, for sure, makes great stuff but their carb tech is old, and you might as well run a CV. And I just find the Mikuni is easier to tune on the off chance it doesn't run perfect right out of the box, which 99% of them do . . .
Old May 15, 2011 | 07:38 PM
Doug S's Avatar
Doug S
Story,
It's all good bud, what ever works is the name of the game. Good friend of mine feels the same way as you about the Mikuni, & they do have those handy plugs for changing jets.
D
Old May 15, 2011 | 07:51 PM
babyray's Avatar
babyray
Originally Posted by NightTrainRob
CV sucks....Mikuni...I put a 42mm on my bike and was the best it had ever ran..no more issues
But now I run a 45mm Mikuni
Mikuni 42 on my 95". Better throttle response than I ever got out of a cv or S&S
jsbridgew
EVO
Jul 2, 2012 03:32 PM
Bellefourchian
Apr 15, 2012 01:09 PM
Glider rider
EVO
Aug 17, 2011 02:45 PM
fxstcguy98
Exhaust System Topics
Aug 8, 2008 10:10 PM
ukchop
Apr 1, 2007 11:01 AM
