Probably a dumb question.....reg or high test gas for my 09 softail deluxe ???
Old Jun 8, 2011 | 05:39 PM
fcsallan's Avatar
fcsallan
Seriously, you buy a $20K bike and your question if it should get what the manual says it needs?
Knocking is not an issue with newer bikes since the computer will compensate by reducing timing until it stops. I would still rather do what the manufacturer says. (within reason)
I also had a car that ran better on regular than high test, but the manual told me to NEVER use other than 87-89 octane fuel, so it was my fault.
You do have the manual right?
Old Jun 8, 2011 | 06:26 PM
lh4x4's Avatar
lh4x4
I use the lowest price at the pump which is 89 octane in this area. I have ridden all over the US and Canada on 89 without a single knock.
The EPA requires that motors sold in the US be able to run on 87 octane.
This is accomplished with knock sensors. When the ECM senses knock it retards the ignition to stop it.
However the rider has more control over knock than the ECM. Just shift at a little higher rpm and don't lug the motor.
I run 89 in my Vettes and Viper again without any issues.
Octane is not power, it is just a measurement value for the gasoline's resistance to ignition.
Power is BTU's. Gasoline has 115,000 BTU's per gallon for any octane level.
Not all gas is burned before it goes out the exhaust. The higher the octane the more that goes out the exhaust.
That is why it is possible to get a little better mpg with lower octane. That is the same reason that the engine my put out a little more heat with lower octane.
I run oil coolers and a fuel pack that has a 12.1 AFR so my engines run strong and cool.
Here's the bikes that I run the heck out of all over the country on 89. From the Arctic Circle to Key West.
Old Jun 8, 2011 | 06:29 PM
lh4x4's Avatar
lh4x4
I should add that some higher mileage bikes knock on 91-93 because they have carbon build up that has never been cleaned out.
Old Jun 8, 2011 | 09:59 PM
Powrsurg's Avatar
Powrsurg
I put the highest I can find which is generally 91 or 93. Bike runs so much better than using a lower grade. Once a season I use an octane booster. If nothing else it does a great job cleaning out the pipes.
Old Jun 8, 2011 | 10:35 PM
DeLuxeLady's Avatar
DeLuxeLady
Originally Posted by HEMI Army
You could go half 89, half 93?
LOL...I suppose so, but really, I don't think it would be worth the trouble to stop the pump and re-start. It was really strange when we were riding to Sturgis last year, the 91 was cheaper than the 87
Old Jun 9, 2011 | 01:59 AM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by t stone
I run non ethinol most of the time. When I cant get that I run premium. It runs way better on the non ethinol.
Stone
Got to be careful though...I got a bst
roysclockgun
General Topics/Tech Tips
19
May 18, 2017 06:20 AM
sbrmike
Shovelhead
Jun 11, 2013 05:55 PM
first dyna 07
Jul 30, 2007 03:18 PM
geo10
Jul 26, 2006 01:21 AM
harleybiker
Oct 30, 2005 08:59 PM
