Front Master Cylinder
Old Jun 20, 2011 | 08:27 AM
Green Hornet's Avatar
Green Hornet
Default Front Master Cylinder
does anyone know if it is fine to take the front master cyclinder cover off and replace it? Or does that mess with all the breaks? My cover is leaking and eating up the paint around it! I would like to just do a quick replacement but I wondering if it will mess anything up with the breaks.
thanks in advance!
Old Jun 20, 2011 | 08:41 AM
Tracker56's Avatar
Tracker56
You can take it off with no problems. Be sure to cover the tank to make sure no fluid gets on the paint. And be sure nothing gets into the reservoir while the cover is off.
Old Jun 20, 2011 | 12:01 PM
F117ewo's Avatar
F117ewo
I don't know why they used the coating they did on the master cylinder. DOT 3/4 fluid eats it up! Now you know why the MoCo sells a chrome cover kit for it.
It's fine to remove and replace. You may want to try some other kind of paint on it, but most paint won't last long in contact with brake fluid. It only takes a couple of seconds of contact to do the damage.
Jake
hd4evr2008
Feb 23, 2019 12:08 PM
italfatboy
Aug 19, 2010 07:21 AM
wvguy
Wheels/Tires
Oct 8, 2009 10:48 AM
Thirdup
Oct 3, 2008 06:10 PM
Drifting Texas
Feb 29, 2008 09:08 PM
