oil cooler frustration
Old Jul 31, 2011 | 08:50 AM
Professor's Avatar
Professor
Default oil cooler frustration
Just added an oil cooler to my 2010 Heritage. When I replaced the threaded connector that holds the filter to the body, I had to make a tool to insert this. The old piece could be removed with a standard socket; the new one requires a 7/16" allen socket. Good luck trying to find one. The largest I could find was 3/8" with a jump to 1/2". Nothing in between. I had to buy a 5/8" cold chissel and use the 7/16" shaft as the allen was able to wedge the chisel end into a 5/8 socket to torques this. Why would Harley produce a part that requires this size unless: (1) they want to sell you the tool (2) they want dealers to perform this job.
I have made odd length and size allens in the past by cutting a bar or using bolts with several nuts on this. Just sayin, so you guys will know what to expect. BTW, I bought the 5/8" cold chissel at O'Reilly auto parts.
Old Jul 31, 2011 | 09:27 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Add an UltraCool with the fan and there is no need for special tools! That is what i run! You neglected to say what brand you are running. Post a link so we know which one requires this.
Drew
Old Jul 31, 2011 | 11:16 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
For cryin out loud...
Some people look for any excuse to bash HD...
A 7/16 allen socket is not some highly specialized tool. If you can`t find an allen socket the size you need, just use a regular allen wrench, cut off a small length, put it in a regular socket.
Old Jul 31, 2011 | 04:21 PM
billfitt's Avatar
billfitt
I used an 1/4 bolt (7/16 wrench) and used a washer to prevent the bolt from going too far in. I've installed 2 coolers on 2 different bikes and this worked great each time.
Old Jul 31, 2011 | 04:52 PM
Tracker56's Avatar
Tracker56
Ingenuity is a lost skill...... If I had to buy all the specialized tools it takes to keep my Ironhead running, it wouldn't be on the road anymore.
Old Aug 1, 2011 | 06:32 PM
Professor's Avatar
Professor
This is an HD oil cooler. BTW, the parts guy at the dealership didn't know that Sears, et al did not offer this. Where did you find a 7/16 inch allen wrench. No one I talked to had one. I have cut these in the past, but this is an odd size. Most places jump to 1/2 inch for 1/2 drive.
Old Aug 1, 2011 | 06:51 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Ran into the same thing this weekend. Used the 12mm allen that I had ground down a few years ago last time I was adding an oil cooler.
Kevin
HDForums Scavenger Hunt Contest
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Aug 1, 2011 | 07:54 PM
Sailrider 1's Avatar
Sailrider 1
A quick google search yields at least 10 stores that sell a 7/16 Allen head socket, including sears.com. I did run into this same situation when installing the HD oil cooler on my Road King Classic. I just ground down a 12mm Allen head socket to 7/16.
Old Aug 2, 2011 | 05:36 AM
Professor's Avatar
Professor
Ya' gotta love the inventiveness of motorcycle riders. When I owned a BMW, I found myself making several different kinds of tools with a grinder.
Old Aug 2, 2011 | 10:09 AM
poppavein's Avatar
poppavein
I'm glad I don't need an oil cooler. One less thing to go wrong.
You would think that Harley would have put one on if it was needed.
homyakchik
Jan 6, 2019 07:21 AM
jkeeton81
Feb 16, 2016 01:35 PM
bdeuce
May 11, 2009 06:55 PM
shortleg
Jul 10, 2008 02:08 AM
dgriffith
Jan 22, 2008 05:44 AM
