Help
Old Aug 1, 2011 | 03:37 PM
arnieb's Avatar
arnieb
6th Gear
Default Help
I have a softail standard (2004) EFI model. I am having problems with it stalling when riding. It doesn't matter if the gas tank is full or empty. When at a stop light the engine revs up and when I try to give it gas it wants to stall. It will stall when I am driving down the road and give it gas, it acts up and then runs good for awhile and then starts acting up again. Also the engine light doen't come on. I had it to the local HD shop and there is no computer codes stored on the bike and it ran perfect for them when it was there.
Old Aug 1, 2011 | 03:44 PM
fcsallan's Avatar
fcsallan
sounds like a leaky intake seal.
KeeBee's Avatar
KeeBee
Sounds like a dirty fuel filter. Hopefully this link helps.
https://www.hdforums.com/forum/evo-c...m-efi-evo.html
Old Aug 3, 2011 | 08:54 PM
arnieb's Avatar
arnieb
6th Gear
I changed the fuel filter still stalling
Old Aug 4, 2011 | 03:29 AM
oct1949's Avatar
oct1949
Might be the ECM also.
Old Aug 8, 2011 | 07:19 AM
arnieb's Avatar
arnieb
6th Gear
I am going to change the check valve and see if that helps
Old Aug 13, 2011 | 09:45 AM
arnieb's Avatar
arnieb
6th Gear
It turned out to be the fuel pressure regulator housing had a hair line crack. Replaced that and now runs perfect!
Old Aug 13, 2011 | 11:55 AM
TheTroupe's Avatar
TheTroupe
Good to hear you found it. Pin hole leak was going to be my guess. Did you hear any hissing sounds before?
Old Aug 16, 2011 | 12:14 AM
arnieb's Avatar
arnieb
6th Gear
no I didn't
IrIeSpringer420
May 18, 2015 09:34 AM
wodom1
Jun 12, 2010 10:57 AM
elevenbravo78
EVO
Jan 28, 2009 05:00 AM
Grumkay
Feb 21, 2008 12:15 PM
Booey424
Jun 16, 2007 03:10 PM
