I have plans to install larger cam and add a Mukuni 42mm to my 04 heritage. Currently stage I with SE dual shorts, carburated jet kit and SE air cleaner. I have toyed with getting heads ported as well a boring to a 95". Can anyone give me advice on cams. All other advice will be appreciated as well.
[/Take out the v-twin and put in a powerstroke diesel...
I put S&S 510 G cams on my ride. Added the PC III and then had it dyno'd. It puts out 82 T and 82 HP at 5100 RPM. It is really a big difference in real world power.
Good luck
Best bang for the buck would be ported and polished heads/Doherty Power Pacc aircleaner/2-1 pipe/race tuner or Power Commander...
You will see a totally different bike without a ton of money and reliability is pretty much stock (actually better if you fuel it correctly with the Race-tuner or Power Commander......
