can i add washers between risers and triple
Old Aug 20, 2011 | 11:55 PM
Joker's back's Avatar
Joker's back
When I was trying the ergos on apes for my bobber, I used the stock bars and spaced them upwards using grade-8 nuts with a bigger ID than the OD of the thread of the longer bolts. I did that for 4 inches! I wouldn't recommend it for longterm use just out of caution, but it got me around and let me tailor the height before I bought bars. So the answer would be that a solid spacer would do the trick for you.
Old Aug 20, 2011 | 11:58 PM
traveler's Avatar
traveler
you definitely need alot of threads in the riser itself to be safe....locktite is a good thing.
poly bushings too.
~Joe
Old Aug 21, 2011 | 01:11 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Holy Crap!!!!
I don't know whether you’re really brave, or a little nuts to try a trick like that.
I'm glad you got away with it, but I have to ask.
What pray tell did you think using fancy grade 8 nuts as spacers was going to do for you?
Used that way they were not going to make things any stronger.
In fact just the opposite would be true.
The more nuts you put into it the more stress you would be putting on the bolt.
No offence, but I wouldn't trust a Rube Goldberg rig like that to stand up to the strain of pushing my bike into the garage.
As for trying to actually ride around with it, no thanks, I'll pass.
I have become very religious in my old age, I'm a devout coward.
Old Aug 21, 2011 | 12:14 PM
Blk and Chrome's Avatar
Blk and Chrome
Have a spacer made at a local machine shop for the size you need
Old Aug 21, 2011 | 02:58 PM
Joker's back
Originally Posted by Citoriplus
Holy Crap!!!!
Brave was dangling from helicopters in hot LZ's, nuts was 2 marriages. This is nothing.
I'm glad you got away with it, but....<snip>....
stress...<snip>....Rube Goldberg....<snip>.....
I have many, many miles under my butt and have been a roadside pragmatist for just about all of them. If you ride alot, you'll find the bike rides itself and you just guide it. You don't tug on the bars all that much. The assembly was solid metal. A mechanical weld, if you will. I put over 3K miles on it that way with different bolts and "spacer" count. I don't always buy, I fabricate and alter.... Like Rube Goldberg, I can integrate different subassemblies to a common purpose or I just hand over my mancard.
You just need some mileage and some common sense. I'm still here.
Old Aug 21, 2011 | 06:41 PM
WFA's Avatar
WFA
Originally Posted by 2wheelfever
i need 1/8 inch of clearance to fit my nacelle, would it be a bad idea to at 2 washer on each side as spacers? (between triple tree and risers)
hey fever...look at "scootworks.com". They have a good selection of spacers and a machine shop to make what ever you want. Reputable folks. I have been in their store and talked to the folks. Store now closed but on-line sales and custom work still functioning...
I bought "fender " spacers on ebay and the vendor actually cut them to my specifications. Under $30 shipped. Still have them without issues.
Explore your options!! Just a thought.
Woody
Old Aug 21, 2011 | 11:17 PM
Been there for the LZ's and have the scars to prove it, but I'm only on my first marrage so of the two I have to say the marrage is better.
Like I said I'm glad you got away with it, but after riding nearly 40 years its my opinion (and we all know opinions are like a-holes, everyone has one and they all stink) that stacking nuts or washers is not a very safe way to ride.
Yes there is only a fairly light loading on it while your tooling down the road minding your own business.
My concern is for what could easily happen to it if your forced to panic stop or suddenly evade the jackasss in the SUV who's trying to use his cell phone to call his girl friend instead of paying attention to the stop sign he just rolled through.
Taking risks is part of life, I just prefer not to take the kind of potentually dangerous or even lethal ones when they are so easily avoided.
I'm sorry, I just don't heal up as easily as I used to so I try not to hurt myself or let anyone else if I can avoid it.
Ragnar Danneskjöld
Sep 12, 2013 10:39 AM
grantb
Ironhead
Sep 7, 2012 07:30 PM
BubbleGutZ
Mar 31, 2011 05:51 PM
lowrider284
Mar 11, 2009 04:28 PM
Gary7
Jan 22, 2009 12:42 PM
