TOURQUE WRENCH HELP
Old Nov 22, 2006 | 08:05 PM
keneds's Avatar
keneds
Default TOURQUE WRENCH HELP
Just bought a craftsman tourque wrench (microtourque) and the scales show FOOT pounds and NEWTON METERS, How do I set it to inch pounds? Do I need to do a conversion to get to INCH POUNDS ? Or am I missing something. Could someone give me some pointers.
Thanks in advance.
Old Nov 22, 2006 | 08:07 PM
Clammy's Avatar
Clammy
Default RE: TOURQUE WRENCH HELP
You'll have to buy an inch-pound torque wrench.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old Nov 22, 2006 | 08:08 PM
Curlingace's Avatar
Curlingace
1 ft pound is 12 inch pounds
lenrough's Avatar
lenrough
one foot pound equal 12 inch pounds... hope you need lots of inch pounds or the wrench won't be very accurate. Best bet is to go buy an inch pound torque wrench if that's what you need.
glide's Avatar
glide
12 inch LBS equal ONE foot LB
You'd be better off to get an inch pound wrench too.
Old Nov 22, 2006 | 08:21 PM
keneds's Avatar
keneds
So what you're all saying is divide by 12 and I'll have what I need. Hey...... I'm a carpenter not an auto mechanic. but now it's as clear as mud. Thanks everyone for your help![sm=loser.gif]
Old Nov 22, 2006 | 08:27 PM
lenrough's Avatar
lenrough
yeah, but considering that the accuracy of "most" over the counter torque wrenches is non-linear and are most accurate between 30-70 pct of range you'd need between 270-630 inch pounds to be "nuts on" with a 10-100 ft pound torque wrench. Not likely you're shooting for 450 inch pounds on a typical screw or bolt ... I'm thinking you're looking for 10-20 inch pounds most often (if you're reading HD manuals).
Old Nov 22, 2006 | 08:35 PM
keneds's Avatar
keneds
I'm installing the clutch cover on my tranny after switching the clutch cable. It calls for 80 to 108 inch pounds of tourque.
Old Nov 22, 2006 | 08:45 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
so device in lbs by 12 to get ft lbs
there is something my bike that says 2 ft pounds so i go 25 inch pounds as my ft lb wrench only goes down to 10
Old Nov 22, 2006 | 08:52 PM
bensonjv's Avatar
bensonjv
I've got a Craftsman Torque wrench too with same scenario.
Option A: divide by 12. Arguably not too accurate and might be difficult to implement without inch measurement tick marks.
Option B: Depending on our application, manual or instructions should give you in/ft pounds and fig-newton-meters. Use the latter.
Option C: If fig-newton-meters aren't provided, Google torque conversions and convert from what the instructions give to what your wrench is graduated in.
